Question about Whirlpool Washing Machines
Washer will not spin r drain model whirlpool la7680xmwo
  • 59 Answers
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Posted on Dec 28, 2016
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
Posted on Oct 28, 2007
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
  • 185 Answers
SOURCE: roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Posted on Mar 26, 2008
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
Jun 29, 2013 - Uploaded by
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
My washer will not spin or drain, what might I do?
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
Jul 12, 2013 - Uploaded by ... your Whirlpool Washer which has this following issues: Notdraining or ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums ...
Sep 09, 2015 | Washing Machines
I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all clog. The water will drain through the pump when the unit is unplugged. Is there a way
it sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Nov 10, 2014 | Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 22, 2011 | Whirlpool Washing Machines
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
15+ year old Whirlpool top loading washer spin cycle broken.
Check the solenoid operation on the outer one that operates the spin bar. There are two solenoids that move back and forth all the time when running called wig wag solenoids. Check for broken wires and movement of the outer slide bar that shifts to make spin. It may need lubrication. Go to to get a diagram.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
Washing Machines Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
