Question about Dryers
Taylor 706 barrel contactor no 220on coil
Got 110 on board and 110 at com but at coil no 220 at coil why
5 Suggested Answers
SOURCE: Heat coils in central air
no heat coming from my central air unit when i cut the heat on. Just cool air. what should i do.
Posted on Feb 25, 2009
co7196
  • 3433 Answers
SOURCE: 110 volt kerosene torpedo heater hooked up 220
the heating elements, fan motor, ETC.
Posted on Jun 10, 2009
Geekman
  • 32281 Answers
SOURCE: Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Posted on Mar 26, 2012
  • 15557 Answers
SOURCE: Samsung dryer will not heat. Have checked power coming in. 110 on each leg, 220 cross termanials..... power in board 110 to both motor and heating system. Thermister, coil and hi temp switch new
The coil is the only item in those that uses the 220. If you only have 110 at the heating coil then there is an issue in the supply.
Posted on Dec 16, 2016
Dec 16, 2016 | Samsung Dryers
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
Then
Mar 25, 2012 | HP LaserJet 1300 Printer
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
May 27, 2011 | Kenmore Dryers
A/C compressor has power to the contactor (220) but will not kick
Check for 24 volts at your contactor coil. If you have 24 volts at your contactor coil, then you should read 220 volts on the other side of the contactor. If you do not read 220 on the other side, then the contactor is failed and needs replaced. If you do not read 24 volts at your contactor coil, then you have to find out where the "break" is. See if you have 24 volts at "common" and "Y" at your outdoor unit. If you do not, the problem is somewhere between your outdoor unit and thermostat. If you have 24 volts at your outdoor unit but not at your contactor, you have a problem somewhere inside your outdoor unit. Using this information, do some more investigating and let us know what you find, we will guide you further from that point. Good Luck! :-)
May 25, 2010 | Goodman CKL60AR60 Air Conditioner
Sr24h dishwasher will not heat water, we have 110 volts to contacts but they will not close in cycle to turn on heater?
if you have voltage to bstr. contactor coil and contactor is not pulling in the coil must be bad on the contactor. try pushing in thecont. manually to see it is not bound up mechcanically, if you can do that replace bstr cont. because the coil is open. dont forget to vote, monomoy
Apr 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Blower fan stays running. Fan relay attached to small circuit board (coil tabs [timer?]). Capacitor on small circuit board had ''fallen out'' of ic board. Tried to get replacement board, and was sold...
If fan runs on 220 you have one constant 110 that always goes to the motor. The other 110 goes through something that will turn it off and on. This being the relay, just like a light switch. This 110 will land on the "N O" (normally open) set of contacts. "Open" meaning the voltage can't pass through. When the relay gets energized the contacts close. This completes the circuit, the motor gets the 220 it needs and it runs. On the relay coil (how it gets it's energy) you need a low voltage common and you need the "G" wire from the tstat. Likely green in color, this is your indoor blower low voltage wire. When the tstat calls for fan, cool or heat, the relay energizes, closes the contacts, fan runs. Good Luck!!
May 16, 2017 | Carrier Heating & Cooling
NO 25VOLTS TO THE COMPRESSOR CONTACTOR COIL
you have a transformer inside your inside evaporator check to see if you have 110 or 220 going to it and 24v coming out if not change
Apr 10, 2009 | Goodman CLT30AER36 Air Conditioner
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
Dryers Logo
23 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
