Question about Watches
Setting 45/7063 Armstrong watch - Watches
What is number of battery for a Armstrong now watch lost old one
Take your watch to a jeweler to have the battery replaced.
May 30, 2017 | Watches
How do I set alarm on Armstrong 45/7041 watch? Did not come with instructions
A= reset
B= Mode
C= ST/STP
D= Light  (edl)
•SETTING TIME AND CALENDAR
1.For time telling mode, press 'B' three times. The seconds should start to flash. Press 'C' to zero out the seconds.
2. Press 'A' minutes will flash, press 'C' to set the minutes.(holding down C will advance the digits faster)
3. Press 'A' hours will flash, press 'C' to set hour.
4.Press 'A' date will flash, press 'C' to set the date.
5.Press 'A' month will flash, press 'C' to set month.
6.press 'A' The day of the week flashes, press 'C' to set day of the week.
7.Press 'B' to finish and it will return to the time.
IF ANYMORE QUESTIONS ABOUT SET FEATURES SUCH AS 'STOPWATCH, SPLIT TIME, SETTING 24 HOUR ALARM, ACTIVATING ALARM, OR SNOOZING THE ALARM'. FEEL FREE TO CONTACT ME @ vannabeltran8.sb@gmail.com WITH 'ARMITRON WATCH' IN SUBJECT BAR AND I WILL SEND YOU PICS OF THE MANUAL.
-Savannah:)
Feb 14, 2015 | Armitron 457004WHT Womens White Nylon...
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
hi,
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
http://www.nike.com/timing/extranet/product/os_alticomp/osac_manual_eng.pdf
If it doesn't help then try another new battrey.
OK
Sep 19, 2011 | Nike Lance Armstrong Limited Edition Lance...
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I just bought a watch its number is ADH4017 i believe its the peach tree watch,something like that. its neon yellow, anyway i cant find the settings to change the time. can somebody please help me i...
TIME/CALENDAR SETTING
1. In normal time display, press and hold A to enter setting mode; chime will begin
flashing.
2. Press C to increase setting value. Press D to decrease setting value.
3. Press B to set and advance to next setting value.
4. Setting sequence is chime, 12/24-hour time, hour, minute, second, year, month,
date, Auto EL.
5. Press A to save data and exit setting mode.
Dec 02, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
Noblia 12 meter watch setting time? I have no
Noblia are made by Citizen watches and you should go to their web site for instructions.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Feb 23, 2010 | Watches
I need a replacement band for my Lance 4 watch.
Go to a watch repair shop or a flea mkt and they are alot of vendors that can find one for you that can match the watch and also change the pins for free and it rather cheap.
Nov 30, 2009 | Nike Lance Armstrong Limited Edition Lance...
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 | Watches
Sportline watch setting time???
With the watch in time mode, press and hold the mode button for 4 to 5 seconds until it beeps and the digits start to blink. Then press the mode button again to advance through each setting. When finished press and hold the mode button to exit the setting mode.
Mar 15, 2008 | Sportline 1000 Memory watch
Watches Logo
54 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
