Furance help - Heating & Cooling
  • Heating & Co... Master
  • 1,660 Answers
They are used for heating homes ;)
Posted on Dec 24, 2016
When furance kicks onafter a while the furnace stops working the range hood and the refigerater. after a while its starts working again.
It is difficult trying to understand what you are trying to convey to me. If you live in an older house, this may be the problem. Your furance, refigerator and range hood may all be on the same circuit. Your furance should have a dedicated circuit, nothing else on it. The refigerator should be on a dedicated circuit also, the range hood can be on a circuit with other devices. To find out what is on a curcuit, go to the panel and find the circuit that powers the fridge, have someone watch to see when the light goes off in the fridge, that will be the fridge circuit. Now check and see if anything else is off, eg. if the range hood doesn't work, then it is on the same circuit. If the furance fan will not operate then it is also on the same circuit. Do the same thing with the furance circuit, turn if off at the panel and see what else does not work.
Remember, the furance and the refigerator need to each have their own dedicated circuit.
Feb 21, 2015 | 2002 Bounder 39r
Why does my furance not turn on when the pilot lite is lit?
Apparently it is not calling for heat. The thermostat needs to close. If it is wired correctly and the stat closes and it still does not start something is bad in the control section. You need to get a tech to help you. Randomly jumping wires is asking for a disaster.
Jan 11, 2015 | Heating & Cooling
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
I recently came to home to find my furance (natural gas) running but it was blowing cold air. I pulled the filter, it was dirty, cleaned it and replaced it. I turned the furance back on and it worked...
You are resetting it every time you take the panel off the front of the unit. It is locking out the circuit board. No. 1 reason for this is a dirty sensor. The flame sensor is the small rod-like part that senses the flame of the burner. It is usually pretty close to the hot surface ignitor (the part that glows bright when the furnace is igniting) Watch your furnace burner light. You will see the ignitor come on. The sensor is a little bigger than a pencil lead and it will be just a couple inches away from the ignitor.
Take the sensor loose and clean it only with fine sand paper or emery cloth. Chances are this will solve your problem. Hope this helps
Apr 21, 2011 | Heating & Cooling
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
No heat.. trying to see why.. gas goes on ands ten off in 10 seconds.. the yellow perge light is flashing - maybe related.. help?
Flame sensor at furance nees to be cleaned. Remove front top cover at furance. Flame sensor is located left of last burner .Remove 1/4inch screw and clean wirh fine steel whole.
Feb 03, 2011 | Honeywell Electronic Programmable...
Just installed a goodman furnance and a/c, there is a blinking light on furance control panel, and the furance motor runs constantly even with the theromostat wire disconnected. thanks for any help
the thermostat wire that you connected to the circuit board is only too long and touching anouther terminal or the insulation on the green wire is bad or last but hardly ever, the fan circuit board is stuck ,which the factory test the systems before shipping out, so the problem is HUMAN ERROR on your part.Thanks, from koolbreezes!
Jun 30, 2008 | Heating & Cooling
Weather King Furance
Hi Cableman. Any 24-36" thermocouple wll work and can be found at your local hardware store.
Hope this helps,
Nov 05, 2007 | Weather King 10AJA6001AH Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
