Question about Garden
How to change an auger belt on a 10hp mastercraft snowblower
SOURCE: Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Posted on Dec 26, 2008
SOURCE: Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Posted on Dec 31, 2008
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
wiringlunati
  • 576 Answers
SOURCE: The auger of my snowblower
I can't give you an absolute answer without checking it out in person, but I'll do what I can to help. What you are describing sounds like the bearings on the auger are going bad. Either they are making the noise. or they have play in them and the auger is then scraping on the body of the snowblower. As to locating parts, Toro maintains a pretty good website that allows you to look up your own parts and/or find a local parts distributor. I hope this helps.
Posted on Feb 14, 2011
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
How do I change auger belt on mastercraft 12/33 Snowblower from 1980s? Thanks ike@muskokaland.com
Yes usually, you will have to remove the roll pin with the proper size punch to remove belt. Post a pic. of the unit so I can see what exactly your looking at. if this info does not help.
Nov 19, 2014 | Garden
I have a 8/26 mastercraft snowblower Model No.
Have you checked all belts and belt tensioners? If so, you will have to tip unit up and take bottom plate off of unit. The drive system consists of a rubber lined wheel that makes contact with a friction plate once handle is depressed for drive. As you change gears you can see rubber drive wheel changes position in relation to friction disc to change speed. If belts are good, I would look in this area for problem. These rubber lined dive wheels do wear out and are replaceable. Also, on some models you can adjust further. Hope this helped. Happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 09, 2013 | Garden
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 13, 2010 | Garden
How do i change the auger belt on a honda hs 70 snowblower?
Remove the auger belt housing cover 4 bolts (10mm), if you are lucky, you can take the belt out, or just cut it. The slide the new belt between the auger and driving pulleys. there is a break pad under the auger pulley, so have someone engage the auger handle and put the new belt on the auger pulley. Or you can remove 10 12mm bolts and separate the auger and engine. Even though you have remove more bolts, it is easier.
Nov 26, 2010 | Garden
How do I change ariens snowblower belts
Oct 12, 2009 | Ariens Garden
HOW DO YOU CHANGE BELTS ON TORO 824 SNOWBLOWER
you have to ssplit the snow blower in half to get to the belts. Its easy but make sure to replace both belts and also check the auger bearing they are known to wear out and the auger belt will not get tight. The bolts are on ether side behind the auger assm
Aug 20, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
