Question about Panasonic Televison & Video
My neighbour has a Panasonic nv-vp33 video DVD combo that has stopped recording sound. The picture is perfect and sound from older recordings is fine. Is it a setting that is wrong?
SOURCE: Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Posted on Mar 24, 2008
SOURCE: No sound
have good picture from pre and recorded tapes, but no sound.
Posted on Oct 03, 2008
SOURCE: Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Posted on Nov 12, 2009
  • 1011 Answers
SOURCE: diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Posted on Jan 29, 2010
Demonic-2011
  • 508 Answers
SOURCE: cannot play certain dvd discs
Panasonic NV-VP33 is a DVD/VCR combo unit. These are good, but limited in DVD media playback formats. It depends on the types of DVDs you are trying to play, and their region codes (if they apply).
This model will NOT play:
DVD-ROM / DVD audio / DVD+R (unfinalised) / DVD-RW / Blu-Ray (obviously).
This model WILL play:
DVD-R (finalised) / DVD-RAM (no finalising required) shop-bought DVD movies / CD-R (for JPEG/MP3/DivX) / DVD-R DL (finalised) / DVD+RW (titled or with a top menu to make them compatible with other players, but again, finalising not required).
You didn't specify which DVDs do not play in your unit.
I would be very concerned if your player didn't read ANY DVDs at all. I assume the image below is what the model looks like. I have never had any problems with mine.
Posted on Mar 12, 2011
Testimonial: "thanks very much very helpful"
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
Cannot play certain dvd discs the make is panasonic model num nv vp33
Mar 11, 2011 | Televison & Video
I have a Panasonic DVD Player/Video Cassette Recorder Model No. NV-VP33 Series. It's about 5 years old and seldom been used. Since shifting to Wellington 3 years ago I have been unable to open the flap of...
Many DVD trays use a belt to make it come in and out. If it breaks or falls off the tray will not move. Look inside see if you can see it. If you find it measure the diameter of the belt in mm. The put these words into google: "drive belt ??mm". You should find, it don't worry if your a few mm out.
Sep 15, 2010 | Panasonic Televison & Video
Sound lost on some recordings stored on the hd of my Panasonic
Double check your scart is pushed in securely. It amy have worked loose.Hence picture/no sound
Mar 12, 2010 | LG RH-4820 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Panasonic NV-VP33, When you play back VHS tapes on the VCR the picture quality is poor & covered in inetrference have tried the tracking adjustment but this doesn't help. played a tape recorded on this...
Hi,sounds like your tape heads are dirty.Do not clean them with a tape cleaner as they do more harm than good.They need to be cleaned by someone who knows.Hope this helps. jamie
Mar 05, 2009 | Panasonic Televison & Video
Panasonic NV-gs50
where can i get drivers for the NV-GS50
May 09, 2008 | Panasonic NV-GS50 Mini DV Digital...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
