Question about Water Water Heaters
My ideal logic combo 30 is giving me hot water which then reduces to lukewarm, any ideas?
    Top Expert:
  • Water Master
  • 43,095 Answers
Call a plumber and have them replace the DIP tube
Posted on Apr 09, 2017
  • 123 Answers
SOURCE: Whirlpool self-cleaning water heater--water is hot
I dont know if this is going to post twice but I need to make sure you get it. I sent one asking if this "luke warm" effect occurs during any specific time frames as "self cleaning" water heaters flush the system from time to time. It may in fact be your thermostatic control assembly which sits on the front of the water heater. Let me know about the frequency of the "luke warm" spells and we will see if we can narrow this down.
Thx
P.S. If it is your thermostatic control do not change it yourself unless you know precisely what you are doing. If installed incorrectly they can be very dangerous and life threatening.
Posted on Aug 20, 2009
  • 36 Answers
SOURCE: ideal classic LXFF not igniting but still giving
ch themistor may be faulty,or divertor not working.
these are the two things that may cause this
Posted on Jan 25, 2010
  • 349 Answers
SOURCE: water is lukewarm.
Make sure you have power going to elements from thermostats. check lines going to elements.
Luke warm water is the result of an element gone bad most of the time. One at th etop gone will cause you to get just luke warm water and one at the bottom gone will give you real hot and then cold.
The elements are not to exspensive so if it has two you might as well replace both of them. If you just put 1 new one in it will work the old one till it goes.
Cut power off and cut water off to water heater and drain heater, open hot side on any faucet to help it drain. once drained remove element they have a tube type socket at hardware stores for the removal of it.
Put elements in and fill water heater till all air is out of lines before turning power back on. make sure water is flowing out of all faucets before turning power onto water heater.
The reason being is the elements has to be in water not open air in tank or it will blow new ones.
Posted on May 16, 2010
heatman101
  • 43501 Answers
SOURCE: We have a Siemens tankless
I don't think that the cold weather is the problem....
The problem would be more like a flow sensor problem or a hot water temperature sensor problem....
The most likely cause would be a flow sensor problem...the sensor is not sensing the proper water flow all of the time and is not then boosting the gas pressure enough to give a hot enough fire for the amount of water flow going through the heater... then the water gets just luke warm....
the flow sensor is probably sticking and needs to be replaced...
heatman101
Posted on Jan 22, 2011
  • 50 Answers
SOURCE: eratic hot water flow
Bosch 1600H NG??? I suppose. If so you need a digital manometer.
Take a static (off) reading then leave it hooked up and start flow. Watch pressure draw down and you should see the heater draw Water Column down below 5" as the pocket of NG in the pipe just before the unit draws down to minimal to keep heater lite. In that case problem in gas line size/gas line run length, Meter pressure.
If you have and maintain in operation 5" WC then is probably the water valve needs rebuilt along with a new diaphgram and also the water filter should be replaced too. This occurs esp after 2-3 year as Bosch specs rebuild at 3 yrs on the Maint Schedule. Also clean all the faucet aerators for good flow above 1.25 GPM Min at all faucets.
Under a single faucet flow (laundry sink) of 2.25 GPM the flame bed of the Unit should be 1"+ high and uniformly Blue.
I assume at this time you either have a Maint problem or you could be overflowing the heater's Winter capacity. This unit @ 70F rise only makes about 2.2 GPM. It's strictly a single use faucet heater at 117,000 BTU.
When you do the Maint look to see if there is corrosion between the GV pushrod and the water valve pushrod. Notice there is a huge mis- match in the 2 rods sizes.These units occasionally (more the 125B) corrode there and the GV will seize on and boil the heater dry and open a seam so you really want to maintain it to Bosch Specs and Schedule.
Note: This is a gas appliance & requires skill and knowledge to service. While Bosch may say you can DIY, I'd readily advise a Bosch approved Service Tech or Plumber do any rebuild. The Digital Manometer alone is a $100-150.00 item and it's the ONLY way to get accurate gas pressure readings.
Posted on Mar 14, 2014
Testimonial: "Sounds like this is the solution to my problem. I will give it a try. Thanks"
My logic 30 combo boiler has hot water but no heating any advice
Check water pressure in system , bleed air in rads check and see if pump is working
Dec 06, 2016 | Water Water Heaters
We just installed a hot water heater that's
1) Test elements, and if elements are good, then replace both thermostats.
Takes about 20 minutes. Power is off.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Label on side of water heater shows volts and watts.
For 4500 watt elements, you need 30 amp breaker and 10 gauge wire.
Move water heater wires to different same-size breaker.
http://waterheatertimer.org/Color-codewire.html
3) Open the links and do the work, or call plumber to do work, or call manufacturer for warranty coverage.
If your wire and breaker are problematic, then service is not free.
Feb 07, 2013 | Water Heaters
Water heater needs a jump-start every morning
Did they change the thermocaouple or the gas valve/thermostat???
My gues is that they changed the thermocouple and NOT the gas valve which also has the thermostat in it.
The gas valve is the problem... make them change that or give you a new hot water heater.
Heatman101
Mar 21, 2010 | Water Heaters
Ideal classic LXFF not igniting but still giving
Dec 31, 2009 | Jason Natural Cosmetics Jason Forma...
Electric hot water heater gives lukewarm water
replace upper thermostat and hi limit switch. These are usualy made in one piece. On a two element heater, only one element comes on at a time
Dec 25, 2009 | Water Heaters
Water is lukewarm. Not hot! Two year old tank, 220 amp is present. Both sides of relay have 220.
Dec 16, 2009 | Little Giant Water Heaters
When i turn on the cold water to adjust the temperature of water - the hot water turns completly off. I cannot turn on the cold water at all. It is either all hot water or all cold.
It might be a question of inadequate flow. All tankless water heaters have a minimum flow rate that must be met, typically .5-.9 gpm, before the heater will operate. In the summer time the incoming ground water temperature is higher, causing you to mix more cold water and less hot water to get a lukewarm temperature. This can reduce your flow rate near or below the minimum flow rate.
Here's a test for you, try running running a sink while taking your next shower. If the hot water remains mostly constant throughout, then your problem is with flow at the showerhead. The flow at a shower head can be reduced by buildup of scale and sediment. Also all showerheads have a flow restrictor that limits flow to 2.5gpm (some even less). Removing the restrictor will increase the showerhead flow rate as well.
Also look for any error code displayed on the digital read out of the heater. Some heaters will flash on their burner indicate light as well.
Aug 17, 2009 | Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
104 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
