Question about Saeco Royal Professional Espresso Machine
Ventilate sign is showing and nothing works
I have recently had the boiler and pump replaced on the machine. After three months or so the "descale" sign came up. I was following the instructions to descale and pressed the "Hot water" button. Up came "Ventilate" and every button went dead. Pushing the hot water button brings up "Hot water" above the "Ventilate" sign, but nothing happens. Please help. span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; } span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
    President:
  • 1,618 Answers
Open the steam valve when the hot water words appear above the ventilate
Posted on Jul 22, 2009
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 19, 2014 | Gaggia Titanium Espresso Machine
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Machine stuck in ventilate mode after aborted DESCALING. When descaling tripped circut breaker on the power circuit.
Hi
This means you probably have a leak inside. Usually the seals from not descaling enough. The steam boiler is over the power switch and will short the power switch. You can replace the seals in the steam boiler hoses, or tighten the fittings and probably save the machine, but change the water hardness setting in the menu to 4. This setting has saved many machines, but you mest descale your machine when it tells you. This also saves the machine.
Jan 21, 2010 | Saeco Royal Professional Espresso Machine
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
Descale and ventilate
I think your magnetic valve have to be replaced.
It can also be stop in the pipe to the rapid steam boiler in your machine.
/Mirran
Sep 01, 2008 | Saeco Royal Professional Espresso Machine
Ventilate problem
need to go through menu to factory reset. This gets machine to ready. You now need to decalcify with a citric acid descaler, not vinegar. With the water tank filled with descaling solution go through the menu to rinse option and rinse machine. When finished rinse cycle and with remaining descaling solution push water button open side knob and rinse the steamer system with descaler.
Jul 24, 2008 | Gaggia Titanium Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Stuck on Ventilation
I went through 3 machines (both Gaggia and Saeco--both have the same Rapid Steam system), hours of searching the Internet, and phone conversations with support(?) staff before I came up with what seems to be good options for both fixing the problem and then preventing it from being a problem again.
The Fix. Fixing the problem works better with two people, so I will refer to person 1 (P1) and person 2 (P2). To fix the problem: 1) P1 uses either a turkey baster or the small plastic (and leaky) pump packaged with the machine; 2) while the readout says "ventilate", P2 pushes the hot water button, then turns the machine off and removes the water tank; 3) P1 fills the plastic pump (or baster) with water and inserts it into the water intake valve (as best as you can, it doesn't fit perfectly); 4) P2 then turns the machine on and opens the steam wand while P1 pushes water into the intake using the plastic pump or baster; 5) as soon as P1 is finished, P2 turns off the steam valve. Repeat steps 3) through 5) until the machine has accepted 4-5 good pumps of water. If you get the "fill watertank" message, you must begin the entire process over again (if you get the "fill watertank" message every time, just keep following the process until you get the machine to accept 4-5 good pumps of water); 6) turn the machine off and reseat the water tank. 7) Turn the machine on, press the hot water button, and open the steam valve. It may take a minute, but you should finally get water. Run it until it becomes a steady stream, and then some more...about 8 ounces worth. I have found that this process doesn't always work if the machine is hot. When it's hot, it sometimes won't accept any water into the intake valve.
Prevention. To prevent the problem, I have been successful (so far) by: 1) after steaming milk, I push the hot water button and run hot water through the wand until it is a steady stream, and then about 4 oz more. 2) I always steam the milk first, then run hot water through the wand, and then make the espresso. 2) I always run water through the wand after making coffee.
This seems like a lot of steps, but it really doesn't take that long once it's part of your routine. I've been successful with this process for the last several day and before that, I was getting the ventilate message every time I tried to steam milk. I'm hoping it continues to work! It's really a shame that the technical staff have not come up with a better solution or, at the least, addressed the problems people are currently experiencing. When I called Saeco, they told me they didn't know why it as happening!
Nov 01, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Royal Professional Espresso Machine Logo
490 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
