I have sd850 is digital camera , why when i take a picture at night even i use flash the picture comes out to dark . do i need to use the flash or not. i always put in automatic . if i don't want to use...
Go to your ISO settings and set it higher. take several pictures till you seee wnat works. the flash is only good for about 10 fet if it's truly dark. Turn it up all the way and if it's too bright turn it back till you find what you want. the lower the better untill it's too dark. Try pushing the pictures with your computer and as long as your not a witness for court cases pushing the pichures with your computer can give you some great pictures as long as the cameria got the picture OK to beginwith as the lower ISO settings will give you more to work with as the ISO goes up the quality goes down and as you push with the computer the quality goes down but if the orginanal has enogh ( Juice ) in it and you computer prgram is a good one then you can make good Processed pictures and you may be pushing the limits of the camera. Maybe next time shell out for a better camera that has more than 10 Megapixals and you'll start seeing into the dark, 20 megapixals really do well but how deep are your pockets? Pup a big flood light on the job and use the flash with the best batteries that you can find and maybe you can get what your looking for. I'm a pro but some low light pictures using a tripod and a remote shutter( to remove all shake) sometimes can get the camera to step up and get the best picture it can take. Take lots of pictures and use brade name chips as some of the noname chips can do a low light picture bad I've thrown away all the cheapie chips I had and I only use the Hi dollar ones, and I'm good to go.
Aug 28, 2010 |
Canon PowerShot SD850 IS Digital Camera
