Question about Grilling
Cooking time for standing rib roast - Grilling
  • 59 Answers
SOURCE: Lost instruction manual
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
That is the URL for the manual. I find their recommended temperatures tend to run about 25 degrees hot; be sure you check the internal temp with a quick read thermometer starting 15-20 minutes before it "should" be done.
Posted on Nov 26, 2009
SOURCE: I need the farberware rotisserie manual suggested
All Farberware Rotisserie Manuals are available for download at http://openhearth.info. The manual that has the prime rib recipe is http://openhearth.info/450.htm . However, I have tried this recipe, and if cooked according to those instructions, the prime rib will be overdone. I take mine off at a much lower temperature to allow for carry-over cooking. These rotisseries make the BEST prime rib!
Posted on Dec 24, 2009
  • 221 Answers
SOURCE: Cooking Time
Google "Smokering" and you will find a lot of forums dedicated to smoking food. It is an art in itself but many of these forums are helpful in learning.
The answer to your question is basically put as many racks of ribs that fit without touching and as long as the temperature is maintained they will all cook at the same time. I typically smoke my ribs at 225 for 4-5 hours.
Posted on Jun 21, 2010
walterkunesk
  • 683 Answers
SOURCE: what temperature should i cook a rib roast,
350-375 degrees f
Posted on Oct 07, 2011
  • 51 Answers
SOURCE: how to cook a boneless beef prime rib roast
just make a cut along the rib and then pull the bone
Posted on Dec 08, 2012
Cooking time for 3.91 lb. chuck cross rib boneless roast
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
Jan 05, 2018 | Grilling
How long would I need to cook a 151/2 lb crown roast fo pork on a Weber grill. It has 18 ribs
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. Be sure to cook over the cool side of a two-zone fire and rotate every once in awhile to even out which side faces the fire side.
Dec 23, 2017 | Weber Grilling
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
I want to cook a rib roast in the pressure cooker. How long to cook? This is NOT a pot roast!
Please don't! You will ruin the prime roasting joint in a piece of beef rib. If you want to boil meat in a pressure cooker, use Tri-Tip or Topside. Roast uncovered in the oven for 1 hour and 15 minutes. Rest for 15 minutes, remove from the bones and carve. You can roast the bones with BBQ sauce as a snack another day.
Happy Easter
Andrew - Master chef qualified 1971.
Mar 27, 2016 | Home
At what temperature do you cook bone in and boneless prime rib and how long per pound
13 - 15 minutes per pound @ 300 - 325 degrees F, pull when meat is 125 F - 130 F (internal temp.) for rare to medium-rare. Err on the low side. Allow to rest; the meat will continue to cook while resting. For example, if you cook it to be medium-rare (130ish F), then pull it out of the oven, and let it rest, it will end up being medium to medium-well (140 - 145 F) once cut. So be aware.
Bone-in, bone-out it doesn't really matter, because the bone is not in the center of the meat. It's best to let the prime warm at room temp for a period of time, before cooking. An hour or so from the refrigerator (not frozen).
Some people like to place the prime into a hot (425 F) oven or grill/smoker for 10 -15 minutes, then turn down to roasting temp. This is done to sear the outside, which will give it a crispy/seared outside. This doesn't "lock in" flavor, juices or anything else, it is more of a visual and texture thing. If you do this, the cooking time will be reduced, because the oven/grill will have to come down in temp over a period of time while the meat is cooking. I don't recommend doing this with prime rib. It ends up being overcooked and tough, due to the fast then slow roasting of the meat.
What you want to keep in mind is: roast the meat low and slow. Check the internal temp, with a meat thermometer, early to avoid overcooking. Don't forget the internal temp of the meat will rise after taking it out of the oven. Let it rest for 10 - 15 minutes before slicing the meat.
Mar 26, 2016 | Grilling
Cooking a 22.8 lb standing rib roast
To have this cooked to a medium will be about 18 mins a pound. Cook a shallow pan at 325 for that amount of time. If you would like a crispy exterior then heat the oven to 450 put in the roast for about 20 mins then reduce heat back t 325 to complete cooking. Before you start rub the entire roast down with equal amounts of salt and pepper. LOTS OF EACH.
Dec 24, 2015 | Kitchen Ranges
Cooking time
51/2 rib roast cooking time for medium rare
Jan 04, 2014 | Crock Pots & Slow Cookers
Dec 23, 2009 | Farberware FRA10ST 10-Cup Rice Cooker
Grilling Logo
57 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
