Question about In Microwave Ovens
Apollo Halftime oven just quit in Microwave mode and now service blinks in the display panel
MicrowaveSvc
  • 9098 Answers
SOURCE: LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 15, 2007
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1505 Microwave
I would first suggest that you be sure every single wire got reconnected where it belongs.
Here is a diagram: http://www.microwavedisplay.com/r1500_series_wiring.pdf
If you still have toruble, see http://www.microwavedisplay.com
Posted on Nov 29, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: display went out then oven quit
We repair these control panels for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Display panel (right side) on
The first thing I would do is a hard reset (simply unplugging it for a couple of minutes) if that has not been done already.
Then one would need to retrieve the technical sheet (mini-manual) found behind the control panel assembly.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here. Just enter your model number from the tag on your unit.
If a reset won't fix it, I would bet there is a loose connection where one of the boards connects to another, or some contamination from grease or steam, etc., at one of those connectors.
A lot of time one can unplug then reconnect the connector, and that will clean it. Or one can unplug the connector and clean the contacts with a soft pencil eraser.
Posted on Sep 26, 2010
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
I have a Appollo AAC24-BIB halftime oven. one of the 2 wires coming from the t stat arced and burnt off and burnt the connection off. Customer service sent me a new t stat and I put it together and ran it...
The cover may be contacting the wires - this will complete the circuit and cause a short. You may need a new part - this time install and ensure that no bare wires are making contact with the cover.
Nov 30, 2014 | Microwave Ovens
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp microwave quit working
Obviously there was a serious short circuit in this unit which is not normally serviceable by anyone but a factory technician. Since this would not be cost effective, I suggest you replace the oven. New ovens are quite reasonable and have many great features.
Ray
Nov 23, 2008 | Sharp R-1490 Microwave Oven
Display went out then oven quit
The main controler board has failed, or there is a fault and the system is in protect mode.
This would have to be properly diagnosed by a tech who is familiar with your microwave oven, and has spare parts and the test gear to evaluate.
Get in touch with the manufacture, or consult the user instructioins to find out where to send the oven for service.
Jerry G.
May 03, 2008 | Dacor DMT2420SS Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
