Lglcd42 c208 ghosting middle part of screen ok after 30mins
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Dark Center of Screen and Ghosting on Right quarter of screen
Your LCD panel has failed, common problem with older Samsung's and Sony's. It will cost more to replace the panel vs. buying a new TV set. If I have helped you please sign my guestbook!
http://www.back2lifeelectronics.com/Guestbook.php
Mar 07, 2014 | Samsung LN46A650 46 in. LCD HDTV
Darker center of screen and ghosting on one side
Check and replace damaged component/s at its back-light inverter board. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
How to unfreeze a samsung c208
hi you can get the unlock codes from here
http://www.mobileunlocksolutions.com/samsung-c208/rs1wp9/
and the instructions about how to use the codes from here
http://www.mobileunlockguide.com/samsung-c208
May 26, 2011 | Health & Beauty
Screen went blank, cannot get TV to respond. turns on and off, but nothing shows up on the screen
CAPACITOR C208 BAD 680UF 16V ON POWER SUPPLY BOARD.
Credit to: http://www.repairworld.com/
Dec 27, 2010 | LG 32LC2D Television
My Sony Bravia KDF-E50A12U has a ghost effect when I play the ps3 or xbox 360. Strangley my virgin media HD box gives a fantastic picture. I have tried the 360 and ps3 on other tv's and they work fine....
Ok, firstly, disclaimer.
This "solution" utilises a "service" menu, that only trained engineers should use. You are not one, you are an "end user". biggrin.gif So am I, but I paid attention. wink.gif
Use of this information is entirely at your own risk, you mess up your telly, it's your own silly fault. Don't go messing with stuff in there you don't know about.
Ok.
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11". (it's on the next "page", keeping scrolling down the menu)
Press the menu button to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Nov 19, 2009 | Sony Televison & Video
Ghost on the screen one is a circle in the middle of the screen, the size of a quarter, the second is a black could the size 2"x 5"
Usually when you get this "ghost effect" the caused by signals reflecting from large buildngs.To improve move antenna for best reception or install an aerial wit a small pick up front print.
Or check you have the correct aerial for the tv installed.
Nov 02, 2009 | Protron PLTV-32 Television
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
50" rear projection sony HDtv and ghosting when using my ps3
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
