Question about Keurig Coffee Makers & Espresso Machines
On my new kuerig k525c plus series---I not only want a large cup of coffee, but i also want it as strong as possible. How do I do that?
On my new kuerig k525c plus---I not only want a 12 ounce cup of coffee but also want it as strong as possible. How do I do that?
SOURCE: More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Posted on Jan 11, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 13 Answers
SOURCE: Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Posted on Aug 28, 2009
  • 236 Answers
SOURCE: Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Posted on Nov 21, 2009
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
Posted on Jun 07, 2010
There is no hole in the bottom of the kuerig k-cup. Is there possibly a part missing?
The Keurig will puncture the K-cup when it is inserted before brewing. If it is not being punctured, the brewer is damaged,
Oct 08, 2014 | Coffee Makers & Espresso Machines
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
Jul 27, 2014 | KUERIG Keurig Platinum B70 Brewing System
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
How to programme it for larger cups of coffee
Press/Hold the large cup button until u reach the desired measure of your coffee... Release it when u think it is enough for your large cup..
Feb 09, 2013 | Nespresso DeLonghi Lattissima Plus...
Coffee is way to strong
Change the settings to Large Cup.
Jan 07, 2013 | Keurig Platinum B70 Coffee Maker
My kuerig onecup won't turn on
Internal breaker has fractured and needs replacement.
Aug 26, 2012 | Keurig B60 One Cup Coffee Brewer
Wont brew an entire large cup
depending on how large, they fill by oz's..a large mug wont fill to the top..Depending on how strong you want your may set for large cup the use same k-cup and the use little setting to double fill....
Dec 18, 2010 | Keurig B50 Coffee Maker
My coffee maker stopped working. I got it going a
In some cases, you can also get the electronics to reset by leaving it unplugged for at least 15 minutes. This may resolve whatever is locking up the machine.
Another possibility is that it may need to be decalcified, especially if you haven't done so recently. Try looking up your model number on the web or on the manufacturer website. Download the owner's manual, if need be, and view their cleaning and troubleshooting sections. If that doesn't work, contact the manufacturer during normal business hours. The unit may require service.
Mar 06, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
