Question about LG Televison & Video
Lglcdc208 ghosting middle part of screen - LG Televison & Video
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Dark Center of Screen and Ghosting on Right quarter of screen
Your LCD panel has failed, common problem with older Samsung's and Sony's. It will cost more to replace the panel vs. buying a new TV set. If I have helped you please sign my guestbook!
http://www.back2lifeelectronics.com/Guestbook.php
Mar 07, 2014 | Samsung LN46A650 46 in. LCD HDTV
Darker center of screen and ghosting on one side
Check and replace damaged component/s at its back-light inverter board. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
Ghost on the screen one is a circle in the middle of the screen, the size of a quarter, the second is a black could the size 2"x 5"
Usually when you get this "ghost effect" the caused by signals reflecting from large buildngs.To improve move antenna for best reception or install an aerial wit a small pick up front print.
Or check you have the correct aerial for the tv installed.
Nov 02, 2009 | Protron PLTV-32 Television
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Red shadow on screen double image
Well this is the fix for the usual Ghosting problem....
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone
Jul 19, 2008 | Televison & Video
50" rear projection sony HDtv and ghosting when using my ps3
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
24 people viewed this question
Computer Repairing
Computer Repairing
