Question about Ovens
Blomberg beo9414x oven not working. I have changed element which had gone and had restricted fan. Element still not heating but not sure if fan is running at full speed
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    huuum
    • 750 Answers
    SOURCE: Oven heating element
    Hello rvready
    Welcome,
    You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
    unfortunately,
    I am not able to find this part either.
    Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
    Today's appliances save you the arm and the leg that such an old oven is costing you.
    You have no idea how it is sucking your money out of your pocket!
    It is unfortunate, that no one told you about this years ago!
    You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
    Shop for a new one and see your bills go down.
    my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
    That means I threw away $7000. in 6 years with my old world attitude.
    Yes I am old fashion and always fix it!
    But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
    Hope I saved you some bucks with my real life stories!
    Don't tell your wife!!!
    Huuum
    Posted on Oct 17, 2008
    barkencoa
    • 3463 Answers
    SOURCE: the main oven of my DY46 Hotpoint is not heating up
    It will be the element that has gone, and it is easy to replace.
    Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
    Posted on Feb 22, 2010
    ginko
    • 19396 Answers
    SOURCE: Oven has stopped heating up
    Hi.
    This oven should have two elements.
    If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
    The probe is located inside the oven cavity.
    On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
    When the probe fails, it will affect both baking and broiling function.
    The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
    If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
    If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
    Regards.
    Posted on Mar 03, 2010
    Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
    2coolrick
    • 560 Answers
    SOURCE: Neff oven not heating have replaced fan element
    it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
    Posted on Jun 05, 2010
    Heating elements in fan oven not working
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Nov 26, 2011 | Smeg Ovens
    Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
    NEmmake sure you removed the correct item first
    replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
    Jan 26, 2011 | Whirlpool AKZ159IX Oven
    Oven fan not working so oven not heating up
    have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
    on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
    Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
    The main oven of my DY46 Hotpoint is not heating up
    Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
    Smeg Oven
    Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
    Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
    Fan oven element
    The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
    Dec 31, 2008 | Ovens
    Fan oven on zanussi electric cooker does not heat up
    From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
    Plz rate this solution.
    Thanks.
    Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
    Smeg oven
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
    Smeg oven not working
    You have a element and or a faulty thermostat
    Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
    Smeg SNZ91MFX1 Fan heating not working
    2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
