Question about Cell Phones
While closing time I have entered some other pin number it got closed. So how to open please I need solution.
  • Cell Phones Master
  • 5,630 Answers
Enter the some other pin number, this is the new pin number.
Posted on Dec 24, 2016
  • 23 Answers
SOURCE: Need Help-Nextel i850 keeps freezing up between opening and closing
go to motorola.com/iden
click united states
click support
click software downloads
(if you have pictures and videos download iden media downloader to retain them)
click software upgrade
click your phone model
make sure you select a date within a year for the warranty info
you will need a data cable to make this work
try to redownload the software to your phone
this might help
Thank You
Sheeraz Khan
Masalama
Posted on Feb 12, 2008
  • 77 Answers
SOURCE: PUK number or a nokia 2600
  • To find out what your puk code you need to contact your network provider thay should be able to give you your puk code so you can use the phone aga
Posted on Jul 18, 2009
fathitkf
  • 1871 Answers
SOURCE: new samsung pc studio opens then closes within 5 secs
Maybe your system is infected by viruses , so try to scan it . if the system is clean , then uninstall the Pc Studio and restart your system , then install it again . that should solve the problem .
rate this if useful please !
Posted on Jan 17, 2010
gal_kunchok
  • 229 Answers
SOURCE: I forgot my PIN number and have failed to enter al...
so there is only one way to get your puk code and that is call to sim costumer care and they will tell you puk code and its absolutely free. remember dont put any puk code.
Thanks
Posted on May 22, 2010
  • 52 Answers
SOURCE: pin code blocked need to enter puk code
PUK code is written on the back of your sim card case simply just copy that code on your mobile phone and you might be able to start your phone
Posted on Jan 18, 2012
About Samsung ER-4615... register is stuck on closed. every time I press any button, it just beeps. Please help asap...
Because it is waiting for you to enter your sign on number. You signed off and now you need to enter your PIN number and press the clerk button (sometimes labelled CLK or CLK#). If you need to program a new sign on, one of the users has a programming manual :
https://the-checkout-tech.com/manuals/cashregisters/Samsung_ER-4615_operating_programming_manual.html
Jun 09, 2016 | Samsung Retail Supplies
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
What is my unluck code?
There are restrictions for the Code,
Hope the llink below can help you. Good Luck :0)
http://web.intuit.com/support/quicken/service/unlock/6273.html
you may obtain another unlocking code or a Quicken CD using one of three options:
  • Online Unlock Tool option (Available for 2003, 2002, and 2001): To unlock your version of Quicken online, please click here and follow the directions on the screen to generate a new unlock code. Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before using the Unlock Tool, as a different serial number will generate each time the program is opened). Our Unlock Tool will check for your previous unlock and issue a new unlock code, free of charge.
  • Online Unlocking Option (Available for 2005 and 2004): To unlock again online, you will need your order number for reference. You will also need to have the Quicken 2004 or 2005 CD in the CD-ROM drive while walking through the unlock process. (Note: You do not need the CD for the New User Edition). Launch the version of Quicken currently installed on your computer. Once launched, go to the help menu and then to the Unlock again option. If you have your Unlock code from either your conformation e-mail or from the Order Status window you can enter it in the blank field. If you do not have the Unlock code, select Go online to automatically unlock Quicken. Quicken will then connect to the Shop Intuit Web site. Enter your Shop Intuit member ID and password. In the Order History window, enter your unlock order and click View. In the Order Details window, click Unlock Code. Close the Shop Intuit Web site. Restart Quicken to begin using your new features.
  • Live Chat option (Available for 2005, 2004, and 2003): To request a new unlocking code, contact Quicken Chat (5:00 A.M. - 5:00 P.M., Pacific time, Monday - Friday and 7:00 A.M. - 7:00 P.M., Pacific time, Saturday - Sunday) Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before chatting, as a different serial number will generate each time the program is opened). Our Quicken Chat Representative will research your account to locate your previous purchase and issue a new unlocking code, free of charge.
  • Telephone option (Available for 2005, 2004, and 2003): To request a new unlocking code, call Quicken Sales and Service at (800) 811-8766 (5:00 A.M. - 5:00 P.M., Pacific time, Monday - Friday) and press "2" for customer service. Please be at your computer with Quicken open and the serial number displayed. (Do not write down the serial number and close the program before calling, as a different serial number will generate each time the program is opened). Our Sales and Service Representative will research your account to locate your previous purchase and issue a new unlocking code, free of charge.
To place an order for the newest edition of Quicken, please visit www.quicken.com. If you have additional questions regarding Quicken 98 or 99, please contact Quicken Sales and Service at (800) 811-8766, 5:00 A.M. to 5:00 P.M. Pacific time, Monday through Friday.
Good Luck.
Nov 07, 2009 | Intuit Quicken 2003 Basic (270902) for PC
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
PIN and PUK code
Network code (network which locked the phone):
23430000= T-Mobile-One 2 One;United Kingdom.
IMEI number (15 digits):
011257000056625
Phone model:
Nokia 1600
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
Your code's are:
#pw+079513401777712+1#
#pw+228125652623623+2#
#pw+404027137232225+3#
#pw+232515167017411+4#
#pw+087803116530105+5#
#pw+742570373007770+6#
#pw+833851766160357+7#
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press
* several times on keyboard of phone...
A message should appear something like "Sim restriction off". That means your phone is now unlocked. Or "Sim restriction on"
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
"Women are, by nature, exhibitionist. Men are, essentially voyeurs."
May 09, 2008 | Nokia 1600 Cellular Phone
Regional code
1.- TURN ON THE DVD PLAYER
2.- PRESS OPEN/CLOSE
3.- PRESS THE FOLOWING NUMBERS 8888
4.- PRESS ENTER UNTIL SHOW "Region code: 9" (Region Free)
5.- PRESS OPEN/CLOSE
OR
1-Turn on your DVD player.
2-Open the tray.
3-Press 9 five times, you will see a number (for me it was 6, you'll see it on the screen, where the DVD displays all messages, like a blue bar up top) then I pressed 9 a few more time until the number being displayed there turned to a 9, when it does then press enter, now it's region free.
Mar 10, 2008 | GPX D2816 DVD Player
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
