Question about Makita Drills
Makita 6227dwe cordless drill can the brushes be replaced.
  • 206 Answers
No, unfortunately this is brushes only come as part of the motor assembly Makita 6226DWE 3 8 Cordless Driver Drill Parts
Posted on Feb 19, 2017
  • 2176 Answers
SOURCE: chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
Posted on Dec 20, 2008
  • 40 Answers
SOURCE: How do i get the chuck off a makita cordless drill
Most hand-held drills have chucks that screw onto the shaft with a right-hand thread. Reversible drills lock the chuck in place with a left-hand threaded screw inside the chuck. To remove this screw, open the jaws of the chuck all the way and use a screwdriver to back out the screw (turning it clockwise, of course, to loosen it). The easiest way to get the chuck off, once the screw is out, is to chuck the short end of a large Allen wrench into the drill, run the drill backwards at low speed, and let the long end of the Allen wrench bang into a concrete floor or a 2x4 or something until you hear a pop and the chuck just screws off. The impacts seem to loosen stuck threads very well. The problem with my drill was that my clutch was damaged and I couldn't get enough of an impact to loosen the threads. I had to get to the clutch before I could get to the chuck.
Posted on Mar 30, 2009
  • 5 Answers
SOURCE: how to replace the brushes on the milwaukee
Depending on age of tool older models did not have replaceable brushes. Change motor.
Newer models are replaceable , go to a service center and get a brush kit for this model. Or online.
Open tool with # 8 torx. Do not separate motor and gear case ,chuck remove as one unit. Brushes are solder in .De solder used brushes . Replace one side at a time. These kits come with new coil tension springs .
Posted on Jul 08, 2009
  • 2176 Answers
SOURCE: I have a DeWalt DW927 cordless drill. It's lost
the brush assembly slides out of the back of the motor. I suggest going to and downloading a breakdown for this tool before starting. I don't think that the brushes are going to be your only problem though.
Posted on Dec 22, 2009
  • 313 Answers
SOURCE: how do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Posted on Jul 31, 2010
Makita bhp454 overheated, not turning clockwise.
It is very common for the armature to overheat and melt down.
Open it up and inspect the armature, it will be very obvious it is burnt.
If it is the case, replace the brushes (#16) and the armature(#14)
Makita BHP454 18V LXT Lithium Ion Cordless 1 2 Hammer Driver Drill Parts
Dec 03, 2016 | Makita Drills
Why will my Makita drill not work when the battery is charged?
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Jul 06, 2014 | Makita 12 Volt Cordless Drill/Driver Kit
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Jul 06, 2014 | Makita 6011DW Battery 1500mAh, 12V, Ni-Cd
Replace brushes on makita bhp452 drill
Here's a link on how to remove brushes.
Oct 06, 2012 | Makita Bhp452Rfe 18v Cordless LXT Combi...
Need carbon brushes for makita mod#m601 10mm drill
I could only find a 601D which is a cordless drill with a sealed motor so you can't just replace the brushes and the motor is discontinued.
Mar 31, 2012 | Drills
How do you remove brushes from a makita cordless drill, the brushes are situates each side at the back cover by caps when i remove cap what do i do next?
you will need to GENTLY pry up on the brush shunt that you see and remove them. reinstall in the reverse order. they generally have a somewhat tight fit in the brush/motor tube
May 07, 2011 | Makita Drills
Can I buy a new motor for a 12 v Makita cordless? How much?
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Mar 09, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
How to diagnose makita 18v impact losing power. Already replaced battery
If the battery didn't take care of the problem check the brushes next. Take the two screws out of the back cover and check both brushes (Part Number 194427-5). They should be at least 1/4" long and evenly worn, if not replace them. If they're excessively burnt or chipped and broken, check the armature before replacing them. If the commutator is damaged it will only shorten the life of the new brushes.
Nov 04, 2010 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
192 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
