Cooling fan switch
It is not necessary to replace the thermo-switch when replacing the radiator. The switch can be replaced separately.
The fan switch is located under the sound box of the air cleaner. It is 2 pin connector. Pull the connector out by pressing the lock which attached to it and short the two pins with a thin auto wire temporarily. Switch on the ignition. The fan will become on. Drive it and see if runs hot.
If the temp reads OK, replace the fan switch. If the problem persists, diagnose the other issues which are concerned with the overheating problems.
