Question about Troy Garden
I have a troy bilt BR-600-z genitor with no fire. unplugged the oil shut off switch and runs good replaced switch and no fire T can unplug coil wire and it will run all wires look good. Thanks REX
  • Rex Sidden
    Rex Sidden Jan 02, 2017
    Thanks for the reply. I finally got it going after a lot of searching. "Thanks" Rex
    New Friend:
Sounds to me like the oil shut off switch is doing its job if replacing the switch has the same result. I would look into what is causing the switch to close.
SOURCE: JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Posted on May 15, 2009
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
wentlanv
  • 710 Answers
SOURCE: need a wiring diagram for Troy bilt lawn tractor
Hi maddiew3,
Copy and paste this link in your browser. The page your wiring diagram is on will open.
http://www.partstree.com/parts/?lc=troy_bilt&mn=13034+13HP+GEAR+DRIVE+TRACTOR+%28S%2FN+130340100101%29&dn=0016500009
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 01, 2011
  • 6468 Answers
SOURCE: How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
Posted on May 24, 2012
stapes613
  • 6 Answers
SOURCE: Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Posted on Jul 28, 2012
Have new out of box Troy built generator. It will not start their is no spark at sparkplug
hey mark, be sure the kill switch is in the on or run position. not being smart but it has happened. check to be sure there is oil in it. if it is brand new it may not have any oil in it and the new ones have a oil sensor that if there is no oil in the engine it will not start. or fire. if everything is good but still no spark you can unplug the black wire from the coil and see if it fires then. if it don't then the coil itself is bad. i would take it back if it was mine. good luck.
Feb 18, 2017 | Troy Garden
Troy bilt troubleshooting
might be low oil sensor trying to shut the engine down, on a hillside the oil would go to one side and the sensor is thing the unit is low on oil.
Jul 28, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
How to check ignition coil with ohm meter
The only way I know how to test a coil is to take the small wire that hooks into the tab on the coil off and then use a spark tester, this way you isolate the problem to either the spark plug or the coil. unplugging the small wire will eliminate the coil being grounded out by the switch.
Jun 05, 2014 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt bronco has no fire. Installed new ignition n gas n oil
Check the spark plug first. If after replacing new plug and still no fire, check the black wire that comes from the coil to make sure it is not grounded to any metal. (best to unhook the wire from switch) If still no fire replace coil.
May 12, 2014 | Televison & Video
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
Troy Bilt pony will not start
no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
Nov 13, 2013 | Troy Garden
No ignition to spark plug
some have a low oil shut off and if the oil is a little low it will shut the spark off then remove the flywheel cover and unplug the small wire from the coil and check for spark if you then have spark it is a wiring problem if still no spark you have a bad coil
Jun 25, 2012 | Troy-Bilt Pony Garden Tiller
Won't start no fire
If you are not getting fire to the plug you first disconnect the kill wire then check for fire again. If you still have on fire replace the coil, if you do get fire check the switch then the wire for a short.
Jul 12, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt 4-cycle trimmer won't stop!
Check all wire connections,where they connect to the switch- to the motor-and to each other sounds like a bad ground
Dec 17, 2008 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
53 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
