Question about Cameras
HAVE A SX400IS want to extend the timer to 20 seconds set at 10 at the moment read manuel the settings that i am told do not come up on this canera please help
Can thi8s be extended
  • Cameras Master
  • 5,412 Answers
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual note spelling, then follow the appropriate link(s).
Posted on Dec 24, 2016
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Mar 26, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
How do you set the self timer to 20 seconds?
1. Go to the "Custom Menu"
2. Go to item 16 and set the self-timer duration (2, 5, 10, 20 secs.)
3. Go to item 4 and set the Shooting Mode to "Self-Timer"
You can also set the FN button to do this (item 11).
Oct 11, 2009 | Nikon D40x Digital Camera
SELF TIMER Z760
Here's how it works.
Press the Menu button. (Some settings are unavailable in some modes.)
Press 'up arrow' or 'down arrow' to get to the 'Self Timer' option which looks like moz-screenshot.jpga clock set at 10 minutes to 10.
Press the OK button.
Press the Menu button to exit the menu.
(This setting will stay until you take a picture or turn the mode dial).
Good Luck
Mar 26, 2008 | Kodak EasyShare Z760 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
