I have just upgraded to a sky router Q and my y-cam HD cannot recognise the wireless
  • Brett Duxbury
    Brett Duxbury Dec 25, 2016
    Hi Teri , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    can it see the ssid from the router
    Is the router 2.4 Ghz wi router use WPA WPA2 WEP maybe y-cam can't handle WPA2 ?
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: vista drivers
You need to run the setup CD for your wireless router on the new computer so they will be working together since you're using vista now....
Posted on Oct 25, 2008
redhaze89
  • 854 Answers
SOURCE: Wireless network card & sky broadband wireless router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
DVIroyce
  • 64 Answers
SOURCE: Is a Philips SB329986 HD enough for Sky HD?
Cant find specs on your Model. If it is HD 720i or 1080i both will work. But then again the Sky box may convert the HD to composit, which makes ordinary old TV sets look fantastic. On a HD set they look even better. don.t worry it will work.
Posted on Nov 08, 2009
Testimonial: "Thank you no need to buy a new tv and am v excited about upgrading now!"
jonsnell4
  • 23226 Answers
SOURCE: I have just connected a new Sky router to my Acer Aspire laptop.My other computer,a Dell Latitude recognises the wireless facility but will not connect due to 'An IPaddress conflict with another syste
You will have to speak to sky and request a new IP address for the router if it doesn't reconfigure after a reset.
Posted on Nov 11, 2014
Sky wireless connector not recognising wireless network
Reset to default settings and reconfigure the SSID and Security Key(password).
Feb 05, 2013 | Computers & Internet
Wifi on laptop
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 28, 2012 | Computers & Internet
Nov 08, 2009 | Philips Televison & Video
Netgear Wireless - G USB 2.0 Adapter
Hello, Joe.
Assuming Sky doesn't prevent access to non-sky internet services (if they did something crazy like that, it is most likely a Sky specific firmware that was put on the router, which would mean you need to put the Netgear firmware back on), I would say you have something set up wrong.
Can you get to the internet through a wired connection? If so, wireless is probably configured wrong. If you can log into the router, that would give you an easy way to find out how thw wireless is set up. goto your web browser (on a wired connection to the router) and type "192.168.1.1" or "192.168.0.1" When prompted, type in your username and password (probably, "admin" and "sky" or "admin" and "admin").
If you can't log into the router then you'll have to try and figure out the connection through trial and error. When you were with Sky and the tech installed your router, did he/she give you an encryption key to use when you connected? If so, I would try "shared WEP" first (providing the WEP key given to you). If that doesn't work, try WPA-PSK.
Hope this helps,
Bill
Sep 03, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
