Model w562 About 20-35mins into the wash the machine trips the electrical mcb at the fuse board When the mcb is turned back on everything is ok Can it be the heating element ?
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
  • 323 Answers
SOURCE: I've had an issues on my Hotpoint WT761 Washing Machine tripping
take off the back and reset the overheat protection, it should be a little red button , maybe the unit was not reset when installed
Posted on Oct 03, 2009
beltronic205
  • 1474 Answers
SOURCE: F-08 error message on Hotpoint Washing machine
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Posted on Oct 07, 2009
kel1guy2002
  • 3740 Answers
SOURCE: cooker trips mcb when put
Hi and welcome to FixYa, I am Kelly.
Most likely it is the element. You can prove that the element is bad by disconnecting one wire and reading the terminal to the outside of the element. If you read a short (ZERO Ohms) the element is bad. It is possible for only one terminal to read to the outside case of the element.
You can find replacement elements in the UK on line here:
http://shop.ukwhitegoods.co.uk/Cooker+%252526+Oven+Parts/Whirlpool+Spares.htm
Your replacement oven element (if it is the bad element) will be listed on the label inside the oven door and will look like this: 5320R488 IRCA 240V 2000W RL6 02476
Since you did not metion if it was a cook top or oven element I listed both.
Thanks for choosing FixYa.
Kelly
Posted on Oct 06, 2010
beltronic205
  • 1474 Answers
SOURCE: washing machine starts but trips mains MCB,
Sounds like short or Electrical leakage,,locate and disconnect the heating element then try this goes faulty now and then....Machine should then run /spin fill ...if so fit new heater
Posted on Feb 10, 2011
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
My treadmill turns on but completely cuts out and trips the house fuse box.. whats wrong
Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
Jul 04, 2014 | Proform Crosswalk 500 Treadmill
Bosch wfo2866gb wont work
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Jan 10, 2013 | Washing Machines
Washing machine starts but trips mains MCB, kitchen is on it's own ring main. Replaced fuse and reset MCB but tripped again, I'm thinking electronic fault, board maybe?
Feb 10, 2011 | Bosch Classixx WFL 2066 Front Load Washer
When I switch on washing machine my fuse gets tripped
hello do you mean the fuse the plug or the mains fuse. if it is the main s fuse and all the electric a trips out the you've got a bad earth. 1 check wired conncetions to the washer if ok then the fault inside the washer the could be faulty component on the power board check for glass fuse make sure it's not blown if has make you use the same rated fuse if this ok then is possible that the motor could have earth out to ground hope it helps
regards
shaun
Jan 09, 2011 | Washing Machines
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Treadmill trips electrics
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Jan 09, 2009 | Proform 380 CS Treadmill !
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
