Buffalo USB drive is not located by Mac Powerbook when connected
It powers up but neither the finder nor the desktop show the drive.
  • eightfootwav Aug 06, 2009
    Thank you Guru. As it turned out the problem was the USB drive. My old powerbook has USB 1.0 ports and the new external drive is USB2.0 which needs more juice to work properly. I bought a powered USB 2.0 port expander and that solved the problem.
  • 358 Answers
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Posted on Jul 21, 2009
Error code10 device refuse to start
PC or mac
try other PC?
try all direct connected, to PC , USB ports.
does the light glow red/green or blue? LED? if not , it has no power.
or is dead.
this slow drive gets its power from the USB port.
and is weak power and problematic , across all platforms.
the horses mouth
http://en.faq.buffalo-global.com/app/answers/detail/a_id/11884/p/1492,1493
Sep 29, 2013 | Buffalo Technology Buffalo 1TB MiniStation...
To connect a ion PIC2PC ot a imac Mac OSX with in the USB-port. I have installed CrossOver and drivers from the packet, it is connected, but my mac cant
Hi. You won't locate the scanner using Finder - the same as you can't find a printer.
Scanners normally only show up when the software that uses them calls for them. I think, however, the problem may be Crossover. Crossover is a brilliant application and it runs most windows apps without too much hassle - it does appear though that it has problems talking to USB connected devices.
I have spent an hour or so this even ing trying to connect an energy recording device via USB but the windows software can't seem to find it.
Jan 14, 2012 | Apple iMac Computers & Internet
I want to retrieve data from a Powerbook 3400c via ethernet. I have a Macbook Pro running Snow Leopard and an iMac running OS10.4
I think the 3400c has a Firewire port, which would allow it to startup in "target disk mode" where it would be just like an external hard drive. That is, hold T at startup to get TDM. I have a Pismo with Firewire but I think the color 3400 is older.
With MacBooks and OS10.5 or later (you are at 10.6) you can do this with USB, also. So it might use the MacBook as the external drive of the PowerBook to transfer files in Finder.
Otherwise, you can turn on AppleShare on both and use Ethernet to transfer files slower.
-Ken
Apr 11, 2010 | Apple PowerBook 3400C Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Will not show up in finder or on desktop,
Is it running? Of late Lacie have had loads of (well documented) problems with power supplies failing and also of some cases failing.
best thing is to connect it to another computer (Mac or PC) and see if it shows up there. That will either eliminate or confirm the drive (Use a known working cable though).
Oct 20, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Issues loading software on powerbook G4
Try using the finder to locate your software packages and simply relocate their icons to the applications folder by opening several new finder windows and dragging and dropping them there.
If you, in fact, went through each application's setup, then the icons were created somewhere on the disk, perhaps on the desktop or even above the desktop, external to the particular user.
Try locating each package back to the applications folder.
Apr 07, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Worked fine on my macbook but not by my powerbook g4 or any other computer
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
Aug 21, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
