My tv screen has frozen - Televison & Video
  • Televison & ... Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 24, 2016
Help my vizio tv, model #e371va is stuck frozen? Help our VIZIO TV is stuck frozen?!My Vizio is froze on the setup screen and Ive tried everything to clear it.. Nor do i have the original remote any...
While the set is on, pull the power plug. Then hold and depress the power button in for about a minute. Then replug set and turn it back on. If that does not reset the tv then you do indeed have a serious issue with the set.
Apr 07, 2017 | Televison & Video
One caption frozen on screen
I believe this is associated with closed caption settings. This can be found in your setting menu, most likely under video. In there turn off CC.
Apr 02, 2014 | Samsung Televison & Video
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
FROZEN USB MENU
I have konka led tv kl26gt611 local key and remote control not working screen red/green /blue flashing only. how to repairing this folt please help me thanks
Nov 25, 2013 | Konka K2386U 23" TV
Screen frozen
I've had this same problem and we only bought this TV back in July. It seems to be getting worse. Anyone have any answers?
Feb 07, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Screen is frozen on with no picture and no sound. Does not respond to either remote control or manual controls. The tv did work and then after a few minutes went frozen.
You need to move further south if it is frozen. It's cold up north :-)
If you've pulled the power from this tv (power cycled it) and it still has this problem ... frozen with no picture and no sound. How a screen can be frozen with no picture, I'm not sure. But it sounds like you are going to be on your way to the repair shop. Or to buy a new tv.
If I couldn't see and couldn't hear, how would I know you were even here?
Nov 22, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
My tv screen is frozen. I can change channels but the screen stays frozen
unplug the TV wait 1 hour plug back in and see what happens set should return to normal.
Jun 08, 2008 | Televison & Video
Frozen lcd screen
that problem is a factory defect in the if and video section of the tv only the manufacturer could remedy that.take it to a tech so that the video board and the IF board be replaced
Apr 02, 2007 | LG 32LC2D Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
