Ran maintenance now it will not print on wifi network, win10
  • kakima Dec 24, 2016
    Hi Yvonne Reid, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
,Printout has white horizontal streaks using win10 or my mini iPad, printer ok using Apple computer, while printing text. Color cart. Showing low ink, but was just replaced
When the ink is run past low (to empty) the print head can get damaged. You can also try 2 consecutive DEEP CLEANINGs .. See 'maintenance' in printer driver under advance setting
Jan 06, 2018 | Apple Office Equipment & Supplies
Windows 10 upgrade on my Laptop shows limited internet , can't get online, any ideas?
Try installing the correct lan and wifi drivers from the computer manufacturer. If there are none available, win10 is not compatible.
Aug 10, 2015 | Computers & Internet
I need to connect my epson printer wifi to my iphone
You cannot print from a mobile device to a WiFi enabled printer directly. Both the printer and the phone need to be connected to the same WiFi network provided by a wireless router or access point, and then you can access the printer through a network or IP print app on the phone.
Oct 09, 2014 | Epson Office Equipment & Supplies
Airprint Printer. We just purchased an HP Deskjet 3050, J610 printer. We would like to know it it can be used with an I-pad or I-phone using an Airprint printer app? If so, where would we find the...
As far as I have tried, every wifi printer worked for me, you should only configure it properly. Most printers doesn't connect to existing wifi - they create their own unprotected network and you will be able to print only when connected to that network. To avoid changing networks every time you want to print, you should connect your printer using USB cable to a PC and configure it to connect to your existing wifi network, then you will be able to print and surf the web on the same wifi network.
Oct 15, 2012 | HP Office Equipment & Supplies
There are two ways to your problem:-
1. The printer is connected to another machine
Set up a Home WIFI system and then add a network printer on the machine that you want to print from. You however need to switch on the pc connected to the printer when want to print. If not sure on setting up a home WIFI system just check on the internet.
2. The printer is WIFI enabled
Just install the printer on your machine and make sure that your printer is hooked up to the WIFI network as well.
Jul 15, 2011 | Computers & Internet
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
