Question about Samsung FE710DRS
My Samsung FE710DRS displays E27. The top half of oven won't work. I've read to replace oven sensor. How is this done?
Error 27 Samsung Electric range
E27
Oven sensor opened(over 2950?)
1. Disconnect power. Open the back cover. Disconnect sensor
harness from control Measure sensor resistance :1080? at
room temperature ? If different value, replace oven sensor.
2. If there is not any problem with oven sensor, Please check
whether there is a damaged terminal or wire on harness.
3. Check resistance of oven sensor connector on main PCB
(Normal:2850?)
Oct 29, 2016 | Samsung Kitchen Ranges
Everything burns before it is done in the oven
You will need to replace the temp. sensor inside the oven. If you could post your model number I can direct you to the part you need.
Dec 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
Display reads " -F3-
Replace the oven temperature sensor. Unplug the range. Open the oven. The temp sensor will be in the top right or left of the oven.A short metal piece about half the size of a pencil. Remove the screws,pull it out carefully. Disconnect the wire plug. Reverse this order to install the new sensor.
Sep 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • May 26, 2009 | Kitchen Ranges
    Samsung FE710DRS Logo
    53 people viewed this question
    Top Samsung Dishwashers Experts
    vince
    gbob59
    Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
