SOURCE: need to change language for spanish to english
just go to teh site mobile heart.com and download the software for any language
SOURCE: Need to change language from german to english.
If you are talking about one of the Casio QT6xxx's then you need to.
I . All peripheral devices and terminals of this cluster should be turned off.
2. Connect all of the peripheral devices (such as printer, display etc.) to terminal.
*In case of wire inline:
3. Connect all terminals by inline.
*In case of wireless inline: QT 6000 or QT6600 models
3. Connect Wireless LAN card.
Operation:
4. Turn on all peripheral devices of a terminal.
5. Turn on this terminal while pressing and holding the initialize switch and then release.
6. Next the screen will say push the INIT (initialize) switch to start IPL.
After releasing the key
The IPL will take a few minutes to copy over.
When it is done, Pick the Language you need. enter"20000" (U.S.)," l0000" (other area:English)," 40000"
(other area:German)," 50000" (other area: French)," 60000" (other area: Spanish) and
press the <OK> key.
I will be making a video of this procedure this week, so visit us @ www.casiohelp.com to view it.
SOURCE: change dutch language to english language before instalation
i used kaspersky 2010 and it was in russian.. i used to chage the language by pressing ctrl+shift+alt +f12. try it! it works!
SOURCE: can't change language to english. preference
Setting this up could be a little awkward because, one cannot understand most of the text. Your case seems to be even worse, because, your system seems to be set up to show few menu options. There should be an icon that turns on, more menu options. (It may look something like Toon mindr menu opties. Check for this menu opties thing or something like that). If you can find that click on it. That will open up more menu options. If this works look for an icon with flags. click on it. That will give you the option to change the language.
