Question about Pool & Spa
Coleman Lay z spa pump has shut down and has a code of 36 on the pump. Whats happening?
    Top Expert:
  • Pool & Spa Master
  • 8,502 Answers
Recirculation pump bad
Posted on Nov 12, 2017
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
compman66
  • 169 Answers
SOURCE: Should I lay the compressor on its side?
I would advise you drain the crankcase of oil before you do that.
Posted on Jan 27, 2010
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
adamh294
  • 310 Answers
SOURCE: lay z spa pump has
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Posted on Apr 27, 2011
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
Need a coleman lay z spa manual
Try Googling (coleman)(model)(manual) without parens.
May 22, 2017 | Pool & Spa
Has anyone had problems with Lay Z Spa pumps?
Lots of people have had issues with them. I'm afraid that they don't last particularly long. The Lay Z Spa's are built to a price.
I have delivered a new acrylic spa to someone today who previously had a Lay Z Spa, he had owned it for about 14 months and was already on his second pump unit.
Apr 22, 2017 | Pool & Spa
My coleman lay-z spa pump is making an intermittent loud sound. All filters are new and spa is clean. What to do?
Could be your motor, bearings going bad or whatnot, pump flow being restricted, bad impeller, or the heater. If it sounds like metal its motor, water noise is the pump flow, and heater is other? I've heard banging and cracks from heater water heating too much and not enough flow. No mater what it is call and see if you warranty is good still.
Dec 11, 2015 | Pool & Spa
Lay z spa heater
with power disconnected take off cover take off heater leads (remember where they go take a picture ore write a note if you turn it on and doesnt blow fuse its a bad heater element
Jul 10, 2014 | Pool & Spa
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
Apr 27, 2011 | Pool & Spa
My spa hums for a few seconds then kicks off. No flow. lights and control display are working.
Is the shut off occuring @ the GFI? & is there an error code displayed on your topside?
If the breaker is kicking off, the best way to troubleshoot is to disconnect all components, (pumps, heater, circ, etc.) & then plug one in & turn the breaker on. repeat the process until you locate which component is tripping the breaker.. then you know whats causing the trouble
Feb 24, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
99 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
