Nextbook windows 8.1 modle # nxw10qc32g get file clipsp.sys error code 0x000007b .?? how do i fix it
  • Computers & ... Master
  • 16,974 Answers
That computer uses solid state ram instead of a hard disk drive. The error that you are getting is because the solid state drive is corrupted. I hope that you backed that unit up when you bough it so that you have an image that you can use to restore it. It may have come with restore software also. If not then you have to get an image of the software, put it on a usb stick and perform a restore on that computer. The solid state ram may have a failure that cannot be recovered from.
Posted on Dec 24, 2016
My nextbook NXW10QC32G keyboard does not work and the wifi will not enable.
Either have the tablet repaired or just replace it, which ever is less money
Feb 06, 2017 | Nextbook Tablets & eReaders
Need manual for nextbook nxw10qc32g please
I just googled nextbook manual and came up with several listings for free, online PDF manuals Not sure which one might work best for you.
Jun 01, 2016 | Nextbook Tablets & eReaders
Manual for nextbook NXW10QC32G
nextbook won't come on and while charging I see a yellow llight.
Feb 24, 2015 | Tablets & eReaders
On nextbook 8se
http://www.androidpit.com/process-com-google-process-gapps-has-stopped-fix
Aug 15, 2013 | Nextbook Premium 8 Se Android
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
I am connected to internet but get error 651
I am assuming you have purchased a new pc with Windows7 and have a DSL internet connection. If so the following tutorial should prove useful. This is a common problem and known bug within the Windows7 framework that they are working to correct. Keep in mind that this fix is only applicable for the Windows7 operating system.
"The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can work around the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system click here to download raspppoe.sys file (unzip)."
http://www.windowsreference.com/windows-7/error-651-with-pppoe-connections-in-windows-7/
Once downloaded and unzipped you may rename the old rasppoe file as mentioned above by right clicking the icon and choosing 'rename'. Then copy the new rasppoe file you downloaded into the applicable folder. You will find this file in the following directory C:\WINDOWS\system32\drivers. Bear in mind, when searching for the file inside the drivers folder, the .sys file extension may or may not be included in the actual name. If the original file is named 'rasppoe' without the .sys file extension in the name, leave this file extension off when renaming and copying as well.
Dec 10, 2010 | E-Machines eMachines Desktop PC
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
