Question about Apple iPad Tablets & eReaders
When on internet the text seems to change to mirror image how do I stop this or is there a fault with my ipad
Can I make a phone call from my iPad?
Yes use text plus or some other type message app that allows voip calls, normally you need to buy/earn airtime. Your iPad must maintain an active Internet connection while in use, if it's the cellular version you can go places with it and make and take calls, the iPad has a microphone built in but I fold it's better to use a headset on iPad for phone calls.
Good luck and thanks
Questions? Just ask! Mr.Mike
Nov 27, 2015 | Tablets & eReaders
My screen is reversed. You have to touch the opposite side of the tablet to select what you want and I just want to know how to fix that.
Here are suggestions I found online:
Press the "font size" key. It should look like Aa or some similar marking. When you click that, you should be able to change the orientation. Use the 5 way controller to move the "selection" up and down and left and right. and then press it when you are over the desired rotation. You want to select the very first A selection
Mar 03, 2015 | Tablets & eReaders
You have sent me details to change my pass code but I do not have Internet at the moment, could you text me.07800666773. Thanks Val Atkin
the password for wifi is usualy on the base of the router on a label
or use LAN cable instead..... you wont need a password
Dec 04, 2014 | Apple iPad 2
My iPad keeps telling me I am not connected to the Internet when I am trying to download ios7.4 upgrade. Yet I know I am.
Internet connections can fail at any point from service provider to your iPad. Just being connected to a wifi network doesn't necessarily mean you still have full internet access. Your modem could be frozen and your wifi router would still seem to be fully functional. Try opening your ipad's web browser and bringing up a couple websites. If you can not get any websites loaded, try troubleshooting your wifi. But if they do load, then yes, you are indeed connected to the internet, and I would recommend restarting the iPad and trying again.
Sep 19, 2014 | Apple iPad 32 GB WiFi Tablet PC
How can I change the Account Settings on my iPad - I do not know the password?
No password, no access. You seem to need to 'Restore iPad' through iTunes (connect iPad to computer and open iTunes, you need internet connection to download system). All data will be lost through a restore, unless you back up (but without password you probably don't access the data anyway...).
Aug 17, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I downloaded the iOS 7.0.2 update and my iPad will not respond. It is on, but my screen shows the iTunes icon with the cord pointing toward indicating that I needed to connect to iTunes. When I connect...
When you have an application fault like that, you need to have iTunes installed on a desktop or laptop computer. Then you connect the iPad to the computer and restore if from there using the iTunes software on the computer. It wipes it clean and reloads a brand new clean operating system. Then you set it up with your Apple ID, only after that, do you restore all your personal data, apps, music and images.
Jul 15, 2017 | Apple iPad (16 GB) WiFi Tablet PC
Is there a way to edit the screen ratio on my iPad 3 HD?
There is no way to edit the screen ratio on the new iPad or any iPad for that matter. They went with 4:3 because the majority of users use the device to browse the internet and read e-magazines or e-books on it. As you know the screen gets cut off when you go to fullscreen or it has those annoying black bars above and below.
If you're looking to watch video do it on a computer or your TV. The new iPad isn't made for heavy video watching IMO.
Apr 18, 2012 | Apple iPad HD
Hi, it seems something is wrong with the way wireless is being broadcast to my ipad, because I can't access internet there, but I can acces it in my imac. Would appreciate it if you can help me solve...
First try to reset network settings by going to Settings, General, Reset then reset network settings
If you still cannot connect, try this other solution:
You can try changing the dns on your wifi connection.
Go to Settings > Wifi > Select the network you are connecting to then change the dns settings to,
Mar 11, 2011 | Apple iPad 32 GB WiFi Tablet PC
Tablets & eReaders Logo
23 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
