Question about Kitchen Ranges
One of my burners will come on and light but when I let go of the clicker it goes right back off. What to do
Main burner ignites and goes right back off
then the thermocouple is not telling the main burner it is able to light . pilot flame might be too small or not close enough to set it to light .
Nov 05, 2015 | Heating & Cooling
Ge cooktop
Usually, any burner makes the same system "click". I'd try to light the one that does work, leave it clicking then turn on the one that doesn't click. This should be just a tempory fix. The switch that turns on the "click" is bad, possibly dirty or the wire to the clicker is bad.
Mar 29, 2015 | GE Cooktops
How to program the Clicker garage remote to a
Go to garage door opener with the remote clicker..somewhere on the opener there is a learn button push it an a led light will stay on.within 20seconds push an hold the button on the remote till it goes out
Oct 05, 2014 | Building Materials
Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
May 17, 2010 | Tec Patio II Grill
Turn Signal Clicker goes on intermittingly. No
SOUND LIKE MULTI FUNCTION COMBINATION SWITCH GOING BAD.
May 14, 2010 | 2003 Mercury Grand Marquis
One of the burners won't light.
HI...TRY TURNING ON ONE OF THE WORKING BURNERS AND LEAVE IT IN THE "CLICKING " POSITION AND TURN ON THE BURNER THAT DOESNT LIGHT.DID IT LIGHT?IF SO YOU WILL NEED TO REPLACE THE SPARK SWITCH WHICH IS LOCATED BEHIND THE KNOB.IF NOT SPARK MODULE IS BAD.HOPE THIS HELPS.PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a 2000 Honda Accord with a factory installed alarm. When I press the button on the clicker it won't disable it. The light on the clicker lights up and the battery is fine. I've tried manually...
When my alarm goes off, it usually happens when someone sticks their hand in the window to unlock the door. In order to turn off the alarm I close whichever door the person opened back, and unlock the door from the driver's side door. This usually turns the alarm off.
Aug 09, 2008 | 1998 Honda Accord
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
