Question about Dyson Vacuums
My dyson v6 overheats and stops running after 10 min or less of use. what is prob
    Master:
  • Dyson Master
  • 849 Answers
Hello, this is Ava with Think Crucial.
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Dec 28, 2016
3 Suggested Answers
  • 231 Answers
SOURCE: Dyson DC07 Vacume cleaner trips on thermal after
first, check both filters on that unit. the premotor filter on the side, and the hepa filter underneath the canister. if those filters are clean move through the suction channel and look for a clog or obstruction. also make sure the canister is clean. I have never seen the thermal go bad on those machines (not saying it cant happen though). it sounds like the filters are dirty or you have a clog. its also a good idea to change the pre motor filter if its older than a yr. the foam is fine but the white material behind the foam gets clogged frequently. let me know if you have any other questions and if this doesnt fix the problem.
Posted on Jan 06, 2010
Testimonial: "Thank you problem is as you say filters need cleaning and replacing"
  • 389 Answers
SOURCE: I turn my dyson on and it runs for 5 min then turns off
The symptoms you describe are typical of overheating. That indicates that there's a blockage somewhere. Follow the instructions in your user manual for removing blockages (or you can download a copy from Dyson website if you need to), and make sure the filters are clean too. That should solve the problem.
Posted on Jan 08, 2010
Dyson upright multi floor vacuum. Was using and stopped running. Electric outlet okay.
Ava B.
Mar 20, 2017 | Dyson Vacuums
MY DYSON RUNS FOR A FEW MINUTES THEN STOPS AND IS FULLY CHARGED
Ava B.
Jan 12, 2017 | Dyson Vacuums
Mymy v6 motorhead shuts off intermitently on high and low power. can I fix this here
Ava B.
Dec 17, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
What is the main difference between the basic dyson v6 and v8 vacuum?
The main difference between the V6 and V8 Dyson models is the mprovements in power and run time of the unit. The Dyson V6 has the V6 motor that pumps out 24 air watts in normal mode. In max mode that number goes up to 100 air watts. While the Dyson V8 comes equipped with the latest V8 digital motor that produces almost 20% more power than the V6 motor. It has the same 2-tier radial cyclones that capture fine dust and allergens. A post-motor HEPA filter keeps those allergens inside the bin. There is also the Bin improvement as Dyson was able to increase the capacity to 0.14 gallons for Dyson V8. This is around 0.03 gallons bigger than the V6.
Ava B.
Oct 22, 2016 | Dyson Vacuums
My Dyson v6 animal vacuum won't charge
Hello. I have the same problem as Shelly. My Dyson will not charge. When removed form the charger the LED light flashes a few times and then stops. The motor does not run at all. When the machine is returned to the charger the same thing happens. LED light flashes , then stops! The power supply from the mains plug is live. Any ideas please? From Eleanor O'Neill.
Oct 04, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
My dyson dc44 just stopped running in the middle of vacuuming, I checked the battery, cleaned the head, I emptied the bin. Is there a reset button anywhere for this machine?
Ava B.
Aug 03, 2013 | Dyson DC44 Animal Cordless Vacuum
Dyson animal shuts of after 5-10 min of use
The "hidden" filter at the base of the unit is the HEPA filter, there is another filter on the side of the vacuum that you can remove and wash with water. Make sure that is washed out. If it's too dirty it will restrict air flow and the motor will overheat.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stops after a few mins of use
You are experiencing a thermal cut-off - caused by a blockage. The machine turns itself off before it overheats. You will be able to turn it on again after 30 mins to an hour after it has cooled down. Call the Dyson helpline to do a full troubleshoot to find the blockage.
Jun 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Keeps turning off
How is the suction at the hose? If low then you still have a clog which will cause the motor to overheat. Otherwise you may have a motor going bad.
Mar 11, 2008 | Dyson DC07 All Floors Bagless Upright...
Vacuums Logo
78 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
