Question about Klipsch Audio Players & Recorders
Klipsch r4b soundbar powers back on after shutdown
2 Suggested Answers
  • 12962 Answers
SOURCE: How to open the remote of Klipsch R-4B soundbar to install battery
Check manual for directions. No manual? go to website for guidance.
Posted on Aug 31, 2017
I have a rsb6 soundbar and sub. No power on sub.
According to the following link: https://www.manualslib.com/manual/1187581/Klipsch-Rsb-6.html?page=14#manual
The power source is the ac/dc converter. If it is pugged in and working you should have power, if no power a replacement should be considered. Hope it is under warranty. If you have a volt meter or test light you might want to check the output of the converter. Circuits inside the subwoofer could be defective.
Nov 25, 2017 | Audio Players & Recorders
Aug 31, 2017 | Klipsch Audio Players & Recorders
How do I open a Klipsch SB3 soundbar to repair it?
The front bezel may be a tight friction fit (to prevent rattles). Gentle application of a putty knife may pry it loose. I know Vizio uses such an arrangement so others could be similar.
Sep 13, 2014 | Computers & Internet
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Does not recognize optical digital
I know this sounds insulting, but I made this mistake. When you buy an optical cable, it has a protective piece over both ends to keep the cable from getting damaged in transit. I worried for hours that my receiver was broken because the cable wasn't putting through a signal. if it si new cable, it'll have this protective piece, too.
Dec 25, 2013 | Klipsch HD Theater SB 3 Soundbar System
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
Schematic for vizio vbs210ws
According to the user manual, the fourthj LED flashing (Error D) means that a thermal (heat) shutdown happened. If Error D, Thermal shutdown, is indicated, turn off the Sound Bar and verify the ventilation slots in the Sound Bar are clear, the Sound Bar has proper ventilation and is not being operated in an environment
that is too hot. If these conditions exist, reduce the volume level for the particular source content being played. My bar did this and I left it disconnected from the Ac power a full day , and it powered up the next day.
Aug 30, 2012 | Vizio VSB210WS Soundbar
How do i connect a soundbar to this receiver? My soundbar just has a red and white coaxial cable and I can't figure out where to connect to the receiver
Hi there, use your pre-outs, you shuld have pre-outs for all channels, I think the soundbar is supposed to create its own surround effect so I would connect it to the front two channels
May 07, 2011 | Onkyo TX-SR608 Receiver
59 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
