Question about Refrigerators
Need parts for Hoover C36 UF 365Litre bottom freezer
    Champion:
  • 363 Answers
Go to appliancesfactoryparts.com
Posted on Jul 22, 2009
Hoover a class, fridge freezer, fridge keeps icing up and is supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | Hoover HCA390FFK Bottom Freezer...
Hoover a class fridge freezer, freezer keeps icing up then fan keeps banging on the ice
You have an auto defrost problem. Need to check element for resistence. if good, check the thermal fuse for continuety. Most of the time i replace both the thermal fuse and the little clixon that is attached to the evaporator coil. Defrost timer is quite robust and very seldom do i need to replace that. You need to firstly defrost freezer overnight to allow cover removal. All components should be visible.
Nov 12, 2009 | Hoover HCA390FFK Bottom Freezer...
Hoover HCA390FFK not draining through drain plug
A common problem is a blocked drain tube. Using compressed air, blow through the tube to clear it. Also, make sure that th refrigerator is level in both directions to allow proper pitch for draining.
Aug 02, 2009 | Hoover HCA390FFK Bottom Freezer...
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Fridge compartment is freezing in my Hoover upright fridge-freezer. Any advice greatfully recieved. Thanks, Owen
have you tried turning down the temperature for the freezer or fridge? The fridge gets its cold power from the freezer, it is siphoned into it. So turning down the freezer temp may help but a sensor may have gone bad in the motherboard of your freezer and not closing off the vent into your fridge
Dec 06, 2008 | Hoover HCA390FFK Bottom Freezer...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
I have a hoover frost free fridge freezer,the freezer seems ok but the bottom of the fridge is freezing all the goods,can you help
you could have set the temperature too low.
adjust the tempearature in the middle section and if it would still freezes the bottom part, use the minimum setting and see if it will make a difference.
tnx 4 using fixya,
drcool
Oct 24, 2008 | Refrigerators
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
