Question about Element Water Heaters
Im getting 320volts on top element and nothing on the bottom y is that
    Top Expert:
  • Element Master
  • 12,962 Answers
How are you getting 320 volts!!!!!!!!!!!!!!!!! ??????????? Impossible.
Check out the element for continuity - if open replace.
Posted on Dec 24, 2016
2 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: My new heater stopped
The elements do not operate at the same time. They are designed to take turns coming on. Try setting the temperature of the top element 10 degrees lower than the bottom one, turn the hot water on in the bathtub. The bottom element should come on first. When you are done checking, turn the top element 10 degrees higher than the lower for normal operation.
Posted on Aug 28, 2010
My caravan carver heaters pressure relief vale keeps blowing any ideas please
Not familiar with that exact heater but if it is an electric heater with a top and bottom element this may be the problem. Electric water heaters usually heat water off the bottom element. If a lot of hot water is used then the top one kicks in through the temperature controls. In some cases if the bottom element burns out, it will try to heat everything with the top element. This sometimes causes the water in the top of the tank to actually get too hot and it opens the relief valve. So you may have a bottom element bad. Otherwise your relief vale may need replaced or you have a sticking temp control making it get too hot.
Apr 11, 2015 | Water Heaters
Have a new electric tank,top element wont come on,replaced thermostat 3 times top element comes on once but next morning not enough hot water&top element wont come on,can someone help? thanks
The top element only comes on when the heater is about out of water. The water is directed to the bottom of the tank. Cold water stays on bottom, Bottom heater element heats water. If you use all that water then the top of the tank gets cold and the top element comes. When the top of the tank is warm, then the bottom element comes on. I would susupect the bottom element as it does most of the work. If you have an ohm meter, turn off electric, and remove wires from element. Check element for continuity. If you don't get reading, then that element is bad.
Oct 04, 2010 | General Electric Water Heaters
We had no hot water so we check the elements with a voltage meter and found the bottom element to be bad. We replaced it. Now there is still no hot water. When we test the voltage again there is continuity...
The elements never run at the same time, it would take to much energy for a standard residential heater. Instead, they rotate powering up back and forth depending on the hot water demand. If you getting 208 to 240 volts on the top element and nothing is happening, the top element is bad and needs to be replaced. If you can swing 30 bucks, replace both elements and both thermostats at the same time. This way you know that everything is new. Check out this generic water-heater wiring schematic.
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
My new heater stopped working after 3 months upon inspection I had 240 volt to the heater and top element and nothing to the bottom element. I replaced the bottom element and both thermostats and their is...
Aug 28, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have 240 volts at thermostat and conection on the tank but nothing at the bottom element. no hot water either
Thermostat may be bad and not suppling power to lower thermostat and element.
Sounds like Thermostat not working properly if no power there..
Do you have power to top element and power going into top of bottom thermostat if it has one.
May 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have change the bottom heatern and the bottom thermostat but the bottom heate do not have current even if the top heater and thermostat have current.
There will be no current to bottom element until top element shuts off. then top thermostat will send current to bottom element only after the top half of the water heater has heated up and shuts off current to top element. Only one element at a time can be on. If current still does not go to bottom AFTER top element shuts off, the top stat could be bad.
Dec 28, 2009 | Water Heaters
One tub of water and im out of hot water
Replace drop tubes where they hook up on top of the tank. You are only getting water from the top of the tank. Remove female adapters(copper) on top of heater.You will find them inside the steel threaded portion of the pipes with a tapered flange to keep them from falling down inside the tank.
Apr 23, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have an old rheemglas fury 22v40 that's leaking from the bottom. What could be the cause? Also, it DOES need replacing, Who does installs at no cost at the time of purchase?
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Dec 06, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
Top Element Water Heaters Experts
Paul Carew
Lawrence Oravetz
richie46
Are you an Element Water Heater Expert? Answer questions, earn points and help others
