Question about Car Audio & Video
I have four 18 inch subs at 1200rms each can the ap4040 push all 2 on each channel comfortable?
    Top Expert:
  • Car Audio & ... Master
  • 12,962 Answers
Important thing is to make sure that the overall impedance to any one channel is never below amp's rated spec. Transistors develop power according to the load that is present to them. The lower the load the more they put out. But if they put out too much power they will exceed their capability, toast themselves, and go to transistor heaven.
Posted on Dec 24, 2016
  • 6 Answers
SOURCE: I have 2 15 inch
Provided your sub can run at a lower impedence its better to tun them in parallel.... you do not need a stereo bass effect!
Posted on Apr 24, 2008
  • 27 Answers
SOURCE: what kind of amp should i run?
i would suggest a pro persicion amp 2400 watts thats what i run and its very decent
Posted on Feb 02, 2009
  • 24 Answers
SOURCE: subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Posted on Jul 07, 2009
  • 417 Answers
SOURCE: how to wire 2 t1 subs in abox to a 1000 watt 1 channel amp
Posted on Apr 06, 2010
  • 1940 Answers
SOURCE: four of these subs to
Click on the link to view the wiring diagram for your setup:
Four 2-ohm dual voice coil subs, 2-channel amp: 2x2-ohm loads
Four 4-ohm dual voice coil subs, 2-channel amp: 2x4-ohm loads
The 2 positives and 2 negatives on each side of each sub is the Dual Voice Coil wiring terminals. Each voice coil has its own wiring terminals.
Posted on Apr 09, 2011
2 ohm amp to 2 10 inch dual coil 4 ohm subs how does it need to be wired
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Apr 08, 2016 | Dual Car Audio & Video
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
I just bought two rockford fosgate t1 twelves duel voice coil 4ohm I'm running a old school alpine v12 1507 mrv 2channel. I want to bridge the amp to get the most out of these subs would it be better...
This amp should run comfortable at 2 ohms/channel. However, your dual voice coil subs are rated at 4 ohms. This means when you connect the 2 voice coils together in parellel (positive to positive and negative to negative both coils wired to one output) the amp will see 2 ohms. So if you connect both subs to one output then your amp will see 1 ohm (not good) If you run the voice coils in parellel but the subs in series then the 2 resistances (ohms) will be added together. So that way the amp will se 4 ohms. This is fine but the amp would push more power into 2 ohms. You can run one sub on each channel if you can split the head unit output to 2 outputs, problem is then you will be halving the amount of power to each channel. Personally I would probably be more inclined to run 1 sub on this amp and run another amp from the pre-outs on the first amp for the 2nd sub. Try to find another amp the same to run the second sub. Mind you, 2 of these amps will need some big power cable to run them but should shake your teeth out!
Hope this helps
May 08, 2011 | Alpine Car Audio & Video
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Want to bridge 2 channel amp to push single 4 ohm dvc sub
Hello k_rabbit89,
A 4 ohm DVC sub can be wired in series like you described for an 8 ohm load or the voice coils can be wired in parallel for a 2 ohm load.
If your 2-channel amp isn't stable down to 2 ohms when the channels are bridged (most 2-channel amps are only stable to 4 ohms when bridged), you do not want the voice coils paralleled. The amp will overheat, go into protection mode, and eventually fail completely. A sub with 2 ohm voice coils would be a better fit. That way, you could series the coils for a 4 ohm load and the amp would operate OK with the channels bridged into that load.
But anyway, for the best power from THAT amp to THAT sub, your best wiring solution would be to wire each voice coil to a separate channel. The problem with that is that the signal to each coil needs to be EXACTLY the same or you will have one coil trying to move the cone out while the other one tries to move it in. You can closely approximate identical signals on the output side by using the same input to both channels. Do this by using only one RCA connection (either right or left channel) from your head unit and split it with a "Y" cable.
Hope this helps.
Sep 12, 2009 | Car Audio & Video
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Whats is the perfect amp?
I have 2 of these 12" running in a Large slot ported box with an:
"Ultra Linear UL2402"
600RMS X 2 @ 4Ohm (Stereo) 1200RMS X 2 @ 2Ohm (Stereo) 2400RMS X 1 @ 2Ohm (Mono)
Can be run in Tri-mode with 3 8Ohm subs, which these subs are. I have not tried this mode. This is
600RMS X 2 @ 4Ohm = Max RMS of your subs. You should run the max of your subs, less wear on the amp you are using , and i doubt you will ever need to turn it up far before it blows out your trunk or window :P
1200RMS X 2 @ 2Ohm = Blown Subs!
Has 4 x 25amp fuses, most will tell you this only has an RMS of around 845, an "ultra linear circuit" produces twice the output power over Modern amps.
Can had on Ebay for around $100. I bought mine for $101.
This Amp pounds, i could quickly tell a difference going from 300RMS X 2 @ 4Ohm with a Kenwood amp. I Had to turn all my settings down on the new amp to have a better balance in sound.
Jan 29, 2008 | Volfenhag ZX-4712 Car Subwoofer
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
