Question about Rigid Vacuums
Rigid 3030 disassembly instructions
How do you remove the plastic one piece hood to split the case? Im at the hood and it wont budge. Is there a hidden screw?
  • 5 Answers
SOURCE: remove plastic shield and access to dirt cup orange filter
I used a table knife in the very front of the brush area, there is an angled chanel. the inner piece of plastic with the roller assy just fellout once all of the screws were removed. I also just wash out the orange funnel piece after vaccuming every 2 months or so.
Posted on Jun 18, 2009
  • 78 Answers
SOURCE: can you remove the plastic hose that leads to the
yeah sorry it is sold as a complete unit and its a real pain to strip down so it better and faster to just buy the whole thing from dysons website
Posted on Oct 30, 2009
SOURCE: how do i disassemble (i.e. which screws do i pull
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Posted on Jan 12, 2010
  • 3 Answers
SOURCE: Bissell Promax 1600 disassembly
small flat tip under lip, pry up, top unsnaps , do it in 4-4 spots, comes right off.
Posted on Oct 18, 2010
  • 694 Answers
SOURCE: I am trying to disassemble
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
Posted on Jun 19, 2011
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
Apr 30, 2016 | Filter Vacuums
Can't get the Sebo S-class filtration off to replace it. I bent the wire down, didn't move much. I tried to pull it off but, it didn't budge.
The filtration cone just pulls out. That's why there's a looped piece of plastic on it at the base of it. The spring wire keeps it in place so that the door can be locked back on.
Aug 27, 2015 | Sebo X4 Bagged Upright Vacuum
I am trying to disassemble a electrolux 2100. I have looked at instructions given by Chemist 1961 and others. On the side, I have removed the rubber covers over the plastic rails but I can't remove the...
May 08, 2011 | Electrolux Lux 5500 Canister Vacuum
I sucked up a piece of plastic. Removed plastic.
This style machine picks up the dirt/debris with the roller, sends it through a fan and into the bag/cup. This is a very common problem since a plastic fan turning at 2000 rpm meeting anything hard is going to cause damage. (Loose Change, toys, anything small) This fan creates your suction and when it is damaged it creates none, it also is the "noisy" part of any vacuum and becomes extremely noisy when damaged.
To Replace this part:
  1. Remove hood (4 screws underneath)
  2. Remove handle assembly ( one bolt through handle and slide off)
  3. remove the belt
  4. Remove the 2 brackets on each side of the motor that hold it in place. (4 screws)
  5. Lift motor off base assy.
  6. Remove rubber cuff around top of motor assy.
  7. Remove the 6 screws on large size of motor assy. and remove cap.
  8. Turn fan (or whats left of it) off of spindle by holding belt drive spindle on oppisite side of the motor.
  9. Replace fan and reassemble.
You can also take this to most any Hoover authorized service center, they would have the parts in stock and could probably do it for less than 50 dollars. Check their dealer locator for a local center.
Best of Luck!
Jun 09, 2009 | Hoover U5290-900 Upright Vacuum
The handle remains in the upight position
Spray some sillicone spray or furniture polish spray at the bottom where the handle adjuster slider can be seen by tipping the cleaner forward. Its usually a plastic bar that should slide. It can become dirty over time or just need lubrication.
Mar 31, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Remove plastic shield and access to dirt cup orange filter
Feb 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
The brushes stopped turning
just repaired mine today same problem.
Turbine drive shaft which drives two sets of plastic gears and which in turn make the scrub brushes rotate has sealed ball bearings and I guess from an evidently poor design moisture some how entered plastic gear casing and the sealed bearings froze up which evidently aren't sealed all that well. Anyway (turbine drive after easy removal from unit 8 screws on bottom one on top can be disassembled by removing 4 screws around gear casing allowing access to the plastic drive gears and the bearings) You can make a decision from there of whether or not a new replacement turbine is a better way to go.
The entire turbine unit can be purchased online for a very reasonable price if you look around the Web.
Dec 19, 2008 | Hoover F7431-900 SteamVac Vacuum
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
Vacuums Logo
Top Rigid Vacuums Experts
JoeVacs
Are you a Rigid Vacuum Expert? Answer questions, earn points and help others
