Question about Sunbeam Food Mixers
Speeds do not work in graduations in Sunbeam Model 2371 12 speed mixer
    Top Expert:
  • Sunbeam Master
  • 12,962 Answers
Problem with speed control device. Check switch for continuity with various speed settings.
Posted on Dec 24, 2016
  • 5 more comments
  • Patricia Deacon Dec 24, 2016
    It does not start off very slow - more like a medium speed - and then does not increase speed until it gets to about speed 8. The boost button does work to increase the speed.
  • richie46 Dec 24, 2016
    Your motor is obviously good - the speed control is bogus.
    Is there anyway to fix that?
    U can try replacing the switch. U can consider a repair option but with small appliances it is usually not cost effective. If the switch is also a part of an electronics board, the latter might also be the cause of the anomaly.
    Can U live with just a few speeds?
    Or what you can also do is just run the motor at full speed and then hook up to it an external speed control for motor. That will also work and restore variable speeds.
    Hubby is a really good fix it man but taking it apart is not obvious. I like the idea of an external speed control. Do you know where I can find the disassembly instructions.
    Thanks very much for you help. Really appreciate it. Merry Christmas to you and yours.
  • richie46 Dec 25, 2016
    Saw a speed control on ebay for motor with brushes for 20 bucks.
    Check out this link
Sunbeam mixmaster 12
There's a governor assembly inside that is bot working any more.
Sep 15, 2016 | Sunbeam 1957 Mixmaster Model 12 Kitchen...
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
Need manual for Sunbeam Vista Mixmaster 70110D
How do i Take rear speed control nobe off on a sunbeam mixer 7-01-10D need to control the speed of the mixer
Oct 28, 2011 | Food Mixers
I have a Sunbeam Model A24 Mixmaster which will only operate at fast speed , I.E. the motor speed control no longer functions. Is it the capacitor? I have checked the points and they appear good.
G'day tandjcox842, did you get an answer to your question? If not, and you'd like to offload your mixmaster, I may be intersted. I've got one that works well but is missing parts. Regardz, Perry.
Jul 17, 2010 | Sunbeam 2545 Mixer
Sunbeam stand mixer's mixing bowl does not turn when mixer is on!
You may have a product failure. Yesterday's Sunbeam is not today's Sunbeam.
Dec 03, 2017 | Sunbeam 2353 Stand Mixer
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
167 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
