Question about Daewoo Washing Machines
I have deawoo DWF 6021 even if I put two clothes it indicates heavy and water level high
3 Suggested Answers
  • 6277 Answers
SOURCE: my dwf -6021 gives a
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 10, 2011
rockeye007
  • 45 Answers
SOURCE: Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Posted on Mar 16, 2014
Dwf 415 dishwasher, overfills with water
gee a whirlpool doing that
check the user manual
the control board failure
water level shut off sensor faulty
water pump failure
check for drain out blockages
http://lastmanuals.com/manual/WHIRLPOOL/DWF-415-W
Oct 13, 2016 | Dishwashers
Mar 15, 2014 | Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
My dwf -6021 gives a E9 error message with a buzz when power is put on....... HOW TO USE?
John C
Sep 10, 2011 | Washing Machines
Why does my Whirlpool washer LXR 7133JQ1 washer not spin the water out of my clothes like it should?
Is the high spin function set? Are you putting too heavy of a load in.. ? The more clothes you put in, the wetter they'll be when done.
Mar 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Frigidaire washer
hi mom,
could it be that these newer models now a days uses less water to wash clothes?
that is what they are boasting about.
energy efficient washing machines..less water more cleaning. ( at least that's what they say) specially on front loading types. not like the top loading where it uses a lot of water.
please check your owner's manual, it may be stated in there regarding water level of the new washer.
tnx 4 using fixya,
drcool
Sep 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
