Question about Craftsman Garden
I have a craftsman mini tiller that won't start. I have replaced the spark plug, used fresh fuel (oil mix), checked the air filter, and cleaned the carborator. What could possibly be wrong?
    Top Expert:
  • Craftsman Master
  • 12,962 Answers
Check for spark (ignition coil).
Posted on Dec 24, 2016
  • 48 Answers
SOURCE: My tiller won't stay running
this is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Posted on Oct 17, 2008
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: Engine won't keep running when using the throtle.
Hi Don. There are two adjustment screws on the carburetor. Start the engine and while it is idling, turn the screw closest the engine (low speed adjustment) counterclockwise until it starts to falter, then back a 'hair' and try the throttle again. If that doesn't work, I would recommend doing what I usually do... put a new carb on and be done with it! Carb is a Zama C1U-K54A
Posted on May 19, 2009
SOURCE: Tecumseh ohv130 engine wont start.
Replace the carburetor. It is not fixable, even though you can buy a rebuild kit for it. Been there, done that-- had to learn the hard way. What?? I said to myself. I've been fixing these small engines (shade tree) for years, and we always could rebuild the carb and adjust for peak performance. I absolutely refused to believe that my "rebuild" didn't "fix" this carb. Hard to believe, but true. Replace the carburetor. This is your "something new" you've learned for today.
Posted on Sep 03, 2009
lindsay836
  • 677 Answers
SOURCE: Mantis tiller 2 cycle will not accelerate. idles
I would pull the tines off of the transmission. You probably have some debris wrapped around the transmission drive shaft(s).
Please let me know.
Posted on Feb 08, 2010
Just stopped running, changed fuel tank,spark gapped at .025 , air filter, added new fuel still won't throttle up and is hard to start. What's next?
If you have a fuel bowl on the bottom of carb remove the cup and clean well and clean the fuel jet as well. If its even partly plugged The engine will not run right.
Aug 04, 2015 | Craftsman 4-Cycle Mini Tiller
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
Mixed 2 stroke oil with gas, won't turn over.
A two stroke fuel oil mix in the engine will not hurt it, it may smoke a little but thats all, i would suggest there is somthing else wrong with it other than the fuel oil mix that he used. a new plug would not hurt incase there is some carbon fouling from the oil.
Jul 18, 2012 | Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
I have a two cycles craftmans gas mini tiller and while i was using it the other day it just shut off and now it want start back
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Craftsman Gas Mini - Tiller/Edger
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Will not get to working speed
RECOMENDATIONS:
-Drain all fuel from the fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running
Hope this tip helps.
R/David
Jan 19, 2010 | Mantis 2-Cycle Tiller
Tiller has sat in weater for a year. I changed the spark plug, and found there was water or gas in the oil (lots of it) i drained the oil and put in fresh but now it wont even start. what is my problem or...
You need a few things for a combustion engine to work. Firstly you are going to need to know a little about engines and how they work.
Fuel - try draining the tank and putting fresh fuel in it - fues does go stale. This will include fuel in the carburetor so that needs drained too. There was liquid, assuming water in the oil, perhaps it is in the fuel too.
Fire - do you get a spark to the spark plug? Pull the plug out and see if you get spark when trying to start - remember the earth of the spark plug needs to be touching the grounded metal such as the engine or frame. Perhaps the electricals have been water damaged.
Air - clean out the air filter and surrounds.
You have already drained the oil and replaced it - good start.
Maybe something has corroded since it has been in the weather for so long.
If it still does not want to start, try pulling out the plug & trying to start - is anything spitting out the spark plug hole? If so, what?
Once that is clean and clear and it still doesn't start but you have spark, try putting a bit of fuel carefully in the plug hole, say half a tablespoon.
How does that go?
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
742 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
