Question about Refrigerators
How do I reset Iberna fridge freezer following a power cut
3 Suggested Answers
  • 117 Answers
SOURCE: Samsung RSH1DBRS twin cooling unit - following a
this may help ">
Posted on Sep 15, 2010
diodeic
  • 1622 Answers
SOURCE: Following a power cut the
Control board may be bad - Unplug the appliance for a few minutes and plug back in. If this does not resolve the problem, otherwise check the fuses on the control board if they are blown or bad, replace with the same rating of fuse, but if otherwise schedule for service.
Hope this help out in solving the problem
Posted on Nov 23, 2010
Can't find the manual for my Iberna Upright Showcase. Model: GD350 and No. 201205. The temperature is much higher than it is meant to be and I can't adjust it.
a UK brand
probably discontinued
cant find a user manual on line for it
my guess is you need to replace the thermostat or the control pad
contact this company
http://www.partmaster.co.uk/iberna/fridge-freezer/catalogue.pl?shop=iberna&path=499408
Apr 30, 2016 | Freezers
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
FRIG KEEPS BEEPING BUT DOORS R CLOSED TIGHT
Not knowing the make and model of your fridge, I would suggest reseting the fridge and freezer temperature settings, inside your fridge. With some fridges like Fisher & Paykel, when the power is cut to the fridge, it will beep until you select the temperature level inside the fridge.
Failing that, a constant beep is a warning code to alert that a fridge component has failed.
Ash
Sep 11, 2011 | Refrigerators
Hotpointt FFA80 freezer door kept opening on its own. noted that ice had formed and was pushing drawers against door. cover removed from coils and found solid with ice. left to defrost but when plugged...
Does the light inside the fridge come on? if it does then you are getting power. If not you are not getting primary voltage. As far as resets or cut outs there is three things that can stop the power to the compressor 1 the cold control (thermostat you set to raise or lower temp) 2 defrost control that is suppose to cycle and put the fridge into the defrost cycle about one time every 24 hours. 3 the over load heat activated cut off that is a small round device usually on the side of the compressor (the big black round can that is in the bottom of the fridge) Since ice formed I would check the defrost control first. It is a timer that should advance slowly on its own but usually can be turned by hand to advance to the defrost position. the defrost timer is usually at the bottom of the fridge and many times can be seen from the front of the fridge when the "kick plate" or bottom grate is removed. if you can find the little knob on the defrost timer try to turn it to the right (clock wise) and see if anything changes. Since the ice formed either the heat element that defrosts the coils or the defrost control has probably stopped working.
Apr 22, 2011 | Refrigerators
MY FRIDGE CUTS OUT WHEN THE POWER FAILS EVEN IF THE POWER JUST FLICKS ON AND OFF WE CANNOT RESET IT HAS WE ARE ONLY AT THE COTTAGE WEEKENDS, SO WE LOSE EVERYTHING INSIDE
other than running your fridge on its own power source or fitting a gas operated fridge,(bottled gas) you must leave it empty,with the door open.....our friends in Canada have gas for heating and fridge /freezer and a generator, so they dont suffer any power cuts in winter.
Sep 09, 2010 | Samsung RB215LASH
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
