I am not getting a signal on my television, I have tried turning all switches off to no avail.
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 25, 2016
When I make a left, or right turn and engage my turn signal , my signal will not turn off automatically after I complete the turn.
Your turn signal switch is worn out or broken...this is located inside the steering column...on older cars (pre-airbag) you need to remove the steering wheel to gain switch out...This part is available for your car at most auto parts stores. Hope this helps.
Apr 25, 2011 | Chevrolet Sportvan Cars & Trucks
I have had a 32" sony LCD Digital TV with built in free view tuner. I am experiencing a problem where on certain channels the TV keeps switching itself off to standby. Is this a TV fault or a signal one,...
if it says no signal or video not available then signal if its just turning itself off then tv i would go to the shop and get it checked out or replaced.
Dec 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Turning signals don't work. all bulbs are working
you dont need a fuse, you need to go get a flasher relay, available at any auto parts store, if you ask, they will probably tell you where it is located!!
Oct 12, 2009 | 2003 Chevrolet Impala
Can't turn off TV unless unlug the power.
Check ur cable or air tv signal.
Turn off and on agian ur your cable box ,if u have free over the air signal u must ajust ur in door or out door antena.Clean ur off/on on ur tv with a little DW40 on the rag clean the switch.Change ur batteries in ur remote,every year,solve most ur tv remote prob.
Aug 09, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No signal...deep sleep
Go to main menu, turn off sleep mode, then find the "autoprogram" feature and select it.
THis will program all available channels, just make sure you tv is set to AIR for regular tv and CATV if you have cable.
The thunderstorm may have reset the television. Hopefully there is no damage done to the tuner
Jul 29, 2009 | Vizio VX37L Television
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Cable quit working says no signal
if u are using the cable input make sure u are un chanel 3 , other way to connect the cable box is thrught the video 1
Jan 17, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Turn signal continues to make the clicking sound
I had the same problem, I found the post quoted below and fixed the problem in about 1 hour without having to replace any parts. Hope this helps!
(I can't seem to get back into the link but had copied the answer - the original link is: http://www.allaboutauto.us/2007/04/07/1999_chevrolet_blazer_turn_signal_clicking_noise.html)
"I had this same problem and fixed it myself. The problem is caused by the contacts rubbing and releasing small particles which conduct small amounts of electricity and cause the flasher relay to click. From a GM Goodwrench mechanic.
Disconnect Battery Before doing this.
You need to remove the turn signal arm from the steering column. This may seem difficult but it really isn't. Separate the top and bottom covers. Find the screws and remove the switch. One is located behind the column and requires some dexterity to get out. I used a Torx bit on a 1/4 box wrench.
The difficult part is separating the switch to clean the contacts. Take your time and you can figure out how to separate the switch. If I remember right, the switch separates and then the emergency signal switch slides out. Also, pay special attention to the way the rotary wiper delay switch is set into the switch.
Once you can see the contacts, clean them off of all lubricant and metal pieces. I would hesitate to use Isopropyl Alcohol for this because off the plastics involved. I just used lots of Q-Tips and a lot of patience.
Finally, get a good Dielectric (non-conducting) lubricant from auto store and cover all contacts with a thin layer. Put the switch back together, reinstall and test.
This took me about four hours to repair. Because I took my time and did not force anything. Once I figured it out it wasn't that hard. The hard part was the rotary delay switch and how it was set into the switch.
I figured if this didn't work, I was going to have to replace the switch anyway, so what the hell. Just make sure your local auto parts store has one of these available if you screw this one up.
Did this about four years ago and problem has not returned since."
Jan 13, 2009 | 2001 Chevrolet Silverado 1500
Hitachi 26LD6600 no signal coming up
You have to switch the Television to the correct input line. This can be done by pressing an Input, or AV of function button on the television remote control.
Nov 08, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
