Hi I recently bought a portable gas heater. I light it and it's fine then anything from five minutes to any hour later it cuts out and goes out. How do i fix it
    Master:
  • 946 Answers
Take it back if under warranty. Must be limit switch getting hot or something. don-ohio
Posted on Dec 25, 2016
Master 125,000 propane heater will ignite but when you release the button it cuts the gas off, takes about 5 minutes before it will stay on and you can change the setting. How can this be fixed?
? doesn't this control On/off on a thermostat ?? the button your referring to is it the piliot test button ? if so I guess you've found a loophole in there test strategy by holding it down for five minutes to get it too stay on ,
what does this heater do when it shuts off on seeing a heated water temp to setpoint (or doesn't it ?) as if the test button is the only way to light it , this button bypasses a few normal safety switches (allthogh I didn't know about the five minute thing) one of the most common safetys that goes on these heaters is the heat exchanger over temp switch , seems the wires get hot and the little connectors fall off it
Mar 29, 2016 | Pool & Spa
I just bought a brand new Kozy World blue flame heater and the pilot light will not stay lit and when it is lit, it goes out as soon as I turn up the nob.
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Nov 25, 2010 | The Companion Group Kozy World Portable...
Furnace will start and sequence fine run for five minutes or so then the flame cuts out....miller type furnace put a new board in last year so now it cycles three times and goes into soft lockout.....
Clean the flame sensor.
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 19, 2010 | Heating & Cooling
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
JBL on rour stop working one hour later every time
Hi, I got my on tour a couple of months ago and it worked fine. But just recently it starts stopping emitting any sound one hour or so after I start it. No sound at all, and the light goes off too. If I press one of the buttons, the light will glim just once.
Aug 01, 2008 | JBL (JBLONTOUR) Computer Speakers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
