Question about Nikon Cameras
Re the D3300, battery is full, screen comes on, but goes off after 5 seconds, Why?
This is a brand new camera, never been used, so I am still trying to figure it out, have looked at numerous instruction videos, but nobody covers what is wrong when the screen automatically switches off.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
That's probably because nothing is wrong. If you want a longer screen time-out, you can set it in the menus.
The camera is designed to be primarily used by viewing though the optical viewfinder. Not only will this generally give you a better look, the camera is more stable when pressed against your cheek than it is held out at arm's length.
Posted on Dec 24, 2016
Is there any way to turn off the screen of a Nikon D3300 whet is conected to the pc by USB?
The screen stays on so that you can monitor the activity taking place.
BTW, it is not advisable to use battery power when transferring images to the computer, since if the camera runs out of power partway through, all images on the card may be corrupted. Use the mains lead - it is what it is for. Alternatively, transfer the images by using a USB card reader, and placing the memory card in that.
Nov 04, 2017 | Nikon Cameras
I have a Nikon d3300 that turns off automatically after i take a photo - can you assist
If the screen display is shutting off, that's a normal function. If the camera is entirely shutting off it might be a bad battery or a very weak battery.
Sep 28, 2016 | Nikon Cameras
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it...
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Mar 28, 2011 | Kodak EasyShare M1093 IS Digital Camera
When using the flash is takes 4/5 seconds before I can take another picture. The taken photo appears for about 1 second then the screen goes black for 4/5 seconds before I can take another picture
You are using a 10 MP camera. Imagine the size of the picture taken. It is massive. And so would the size in megabytes. To save those many MBs is a time consuming affair. that is what takes 4 to 5 seconds. And during that time the camera can do nothing else.
Do not worry. The camera is fine. Just that you have a very good camera and do not realize it.
As regards the photo being visible for a second only, you can change the settings and have the picture on display for a longer duration. That would be fine as while you are viewing the pic, the camera is busy saving the pic file. You would not feel those 4 to 5 seconds at all.
Dec 28, 2010 | Canon Powershot A2000 IS Digital Camera
No picture on screen after 1 second
Try this. Go to your tools menu, look for something like power saver or display off and change the duration that the screen stays on.
Jul 08, 2009 | Samsung Digimax S500 Digital Camera
When I put brand new batteries, it says "Change Batteries"
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Apr 10, 2009 | Canon PowerShot S1 IS Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Zoom lense going in and out when turned on
Try taking the batteries out and plugging it in. If it powers on, put fresh batteries in and try again off the AC. Once it's powered up from the AC, unplug it and see if it stays on. If it does, try restarting it. Good luck.
Aug 18, 2007 | Olympus FE-110 Digital Camera
Cameras Logo
37 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
