Question about The Audio Players & Recorders
I have NB9D-CAR units. It doesn't matter if you use IR headphones or wired, always results in the builtin speakers causing a sort of buzzing. Remove the headphones, then speakers/sound are fine.
jpk528
  • 95 Answers
SOURCE: Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Posted on Feb 17, 2009
romsky79
  • 822 Answers
SOURCE: Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
Posted on May 05, 2009
plnolte
  • 62 Answers
SOURCE: Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
Posted on May 12, 2009
samrat_babui
  • 296 Answers
SOURCE: hp dv71245dx cannot remove from muted state.
hi
Go to Control panel > Sounds and Audio Devices > Volume. Check that Device Volume is at least halfway across the slider and that Mute is unchecked. Go to Advanced and make sure that nothing is mute. Go to Speaker Volume and set the sliders at least halfway across the slider. Go to Advanced, and in Speakers setup choose Laptop Stereo Speakers (if that's what you have). Go to Performance and choose Restore Defaults. Click Apply > OK
plz do inform if this has sorted out the problem
all the best
regards
Posted on Jul 15, 2009
jeevan.m
  • 392 Answers
SOURCE: Unplugged speakers, plugged em in -- now I don't get ANY sound
check ur sound drivers.. check whether they are uninstalled, and try to check in the sound and audio devices in control panel...
Posted on Jul 25, 2009
What is causing humming sound in headphones?
Well, there are a couple things in the troubleshooting process you may want to check first. If Possible,
1. Have you tried a different pair of headphones thru the same jack?, Is it buzzing as well? Then its not the headphones. If the buzzing stops with a different pair, then we proceed to to headphones in question.
so , headphones are buzzing. Both sides? if yes , or even 1-side, then yes, it is a ground issue. can you expose the wiring at the input jack?
Basically, you want to put an ohm meter on each wire and independently check each wire for continuity. check for any breaks in the line, and or check to see if a wire is crossing over to ground via a break. so check each line to itself, then each line to each other.
if you fo not understand on the process of using an ohm meter? you can go to this You Tube link and it will give you a general understanding.
hopefully this gives you a little insight? If not?, ask the question again, and also include the make & model of the headphone set. that always helps;m Thanks,
Good luck.!!
Mar 22, 2016 | Music
VXZ 646 what connections do I require between unit and TV To play DVDs
all you need is to run the RCA outs from the back of the unit to the signal screen, the screen however will need a power source seperate to the head unit. if your screen is only a slave screen and does not have any speakers (or you wish not to use them), nor has any IR for headphones, then you need only to use a single Video RCA, if however it has got IR on the screen and you do wish to use headphones then you will need to use a triple RCA set, (normally RED, YELLOW, WHITE) with red and white being for your stereo sound output, and yellow being for your video.
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 13, 2011 | Clarion Car Audio & Video
Hello! I purchased a pair of M- Audio Av 30 speakers years ago and I've noticed that at times they emit an annoying buzzing sound from the subwoofer parts of each speaker. I normally dont notice it because...
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 27, 2010 | M-Audio Studiophile AV 30 Computer...
Got issues with some kind of background noise that suddenly shows up after some minutes of use... Its some kind of a buzzing sound, that appear once a while and stays there until i turn the sound off.
There are a few things that can cause this kind of sound through your speakers. First off, your cable wire. If it's not attached to the subwoofer, remove it and try a different cable. It could be that a piece of the wiring inside the cable has been damaged. If this doesn't help, your next bet would be to check the sound card inside the computer. Try plugging in a different pair of speakers or some headphones. If you still hear the buzzing sound your sound card needs to be repaired or replaced. Finally, you could have some electrical interference caused by certain devices like a cell phone or your TV. Try turning the devices off and see if the buzzing sound is still being heard.
Dec 26, 2010 | Creative Technology Creative Inspire T3130...
Trouble w ir headphones
check the batteries in the headphones
Jan 22, 2010 | Audiovox Car Audio & Video
Buzzing noise coming throught my headset on my turtle beach x1 headphones
Check if the buzz stops when you remove the talkback cable. If so, then try a wireless controller if you're using a wired one. Also, don't use a play and charge kit because it causes a lot of buzz on the headset.
Jan 16, 2010 | Voyetra Turtle Beach Turtle Beach Ear...
Buzz from speakers or headphone when CD is played.
This is due to improper insulation of wires or improper isolation of power unit with the rest of the unit.
Thankyou
Feb 10, 2008 | Teac CD-X8 CD Shelf System
Dell Inspiron 600m Speakers
Try making sure all the volume mixer settings are less than 90% of maximum as this can sometimes cause this problem
Nov 08, 2007 | Dell InspironTM 600m Notebook
Sub woofer freq prob
Without hearing the noise, it's difficult to determine the exact cause. I've seen enclosures do this if the panels were not glued together well.
Try connecting the speaker to one channel at a time to see if one particular channel causes the problem.
Oct 12, 2007 | Car Audio & Video
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
