Question about Kitchen Ranges
Oven locked & F31 appears,how can I unlock oven
    Top Expert:
  • Kitchen Ranges Master
  • 50,305 Answers
Perhaps if someone knew the MAKE they could assist you better .do a search for it thru Google
Posted on Dec 24, 2016
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
Apr 01, 2018 | Kitchen Ranges
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
Oven shows error F31 when trying to bake
F31 - Shorted Temperature Probe connection
Check the sensor probe connections for damage. Make sure it is plugged into the socket, all the way, when the oven is in use. If the connections are sound, and not separated from their respective contacts, replace the temp probe.
Dec 15, 2009 | Frigidaire Kitchen Ranges
ONLY BROIL WORKS, NEED BAKE TO WORK BEFORE THANKSGIVING
I'll presume you have no "fault code" appear in the display, i.e. F30, F31 correct ? Is it both top and lower oven ? What happens when you select a bake cycle, anything ? Does it appear to be on, but no heat ?
Just need some clarification and details and I'll try to help.
Oct 30, 2009 | Thermador SMW272 Electric Double Oven
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
F31 error code after self-cleaning cycle
Possibly the temperature probe, check the connection and the wiring to it. These ovens have very badly stamped metal inside that will cut through wiring very easily. Temp probe may be bad as well.
Dec 09, 2007 | Frigidaire FGFB75D Gas Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
