Question about Brother Office Equipment & Supplies
Have abrother printer j515w we have a white thing that has come off but don't know where its from when we go to print it say theres not paper but its full
  • Brother Master
  • 3,895 Answers
the white thing could be a paper holder from the paper cassette tray that pushes into a slot in the tray and pushes against the paper sheets and may tell the printer also what paper size is in the tray.
Posted on Dec 25, 2016
Load specified paper in manual feed?
are you trying to print a pdf file ? if so some times the paper size is not correct for the paper you have in the machine or you have the wrong size selected in the menu settings of the printer.
Apr 16, 2013 | Samsung Ml2955nd Black White Laser Printer
Get an error message when printing from computer
did u open the printer and check for paper inside?
Jan 23, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
Pump stall hp cp1700
I know this is years old, but just in case someone else has this problem....
I just had this problem and fixed it quite easily.
Like you, my ink cartridge flooded the ink bay and caused the printer to complain about a pump stall.
Mine was fixed by taking the cover off (u don't need to) and cleaning all the ink off the white strip.
Basically, there's a white piece of plastic with a metal rectangle on it. it sites to the left of the thing under the print heads (the part doesn't move. Under the big part with all the print heads) and to the right of the paper rollers.
It's also the thing that stops the print heads from moving when they're not to be moving.
Mine was covered in black ink. I cleaned it off and turned on the printer to find it working again and no more "pump stall" messages.
I don't know what the plastic piece is for, but cleaning it fixed my problem. Also there's no "pumps" in the printer (it uses gravity to feed the ink).
Jun 22, 2012 | HP Office Equipment & Supplies
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
Black ink marks on prints from Epson R380!
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
York, PA
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
23 people viewed this question
James Cagle
James Cagle
Jim Keysor
