Question about Whirlpool Refrigerators
How do I remove front cover on Whirlpool WRF40 IX fridge. I need to access the PC board
    Sergeant:
  • Whirlpool Expert
  • 448 Answers
Need full model # for proper dissemble bottom cover should just snap off
4 Suggested Answers
aasc
  • 1606 Answers
SOURCE: I have whirlpoolarc1790/ix and i need to change
Most Whirlpool boards , are located behind the refrig , behind the lower panel , on the left .
Posted on Nov 06, 2009
  • 16 Answers
SOURCE: WRF40:
sounds like the thermostat is not working properly because once the refrigeration side of it is either on or off. So I'd say the thermostat is turning it off to early. try bridging out the thermostat and then you'll know. Make sure you unplug it first.
hope this helps
koolman777 (refrigeration technician)
Posted on Feb 07, 2011
deoneweb
SOURCE: I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? deon@electro-web.co.za
Posted on May 26, 2014
Programe the whirlpool refrigerator G 15FSAXVY02
Control board is programmed unplug fridge to reset board if programming is required you have to remove front display cover and remove board there's a plugin on front of board programming tool required you may find it is cheaper to buy new board
Oct 16, 2015 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
WHIRLPOOL WBM35 IX LIGHT NOT WORKING
Check door switch lite will have a switch on door can maybe just a wire off
Jun 29, 2015 | Whirlpool Refrigerators
Where is the control board located in a Whirlpool GB9FHDXWQ01 refrigerator? Is it in the top of the refrigerator accessed by removing the light?
More likely on top of the outside of the fridge, accessed either by taking the top off or the front bit above the door. Are you sure it's a board, not a defrost timer on the back?
May 01, 2012 | Whirlpool Refrigerators
WRF40: It will only work on the lowest temp setting. The PC board has been replaced before
hope this helps
Feb 07, 2011 | Whirlpool Refrigerators
I have a whirlpool WRF40 ix all refrigerator. The problem is that the compressor trips at the high cooling settings (4 and 5) starts again and then trips immediately again. It only runs at 3 or lower....
May 20, 2010 | Refrigerators
Nov 05, 2009 | Refrigerators
Refrigerators Logo
129 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
