Na-F80B2 show U12 - Office Equipment & Supplies
SOURCE: panasonic washing machine model no
it is due to the magnet attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. i got the same problem too but luckily the i found the magnet nearby the washing machine.
Posted on Jan 17, 2011
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
richroth
  • 9472 Answers
SOURCE: The error code U12 shows
The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
Posted on Jul 31, 2011
eugengetz
  • 42 Answers
SOURCE: my panasonic waching machine model is NA F80B2 Error is U 11 U 14
See http://www.manualslib.com/manual/783539/Panasonic-Na-F78b2.html?page=13#manual
Posted on Feb 06, 2015
  • 2992 Answers
SOURCE: Panasonic model Na-f70b2 error. U12 and stop motor
Try this: it should give answers to the "self-diagnostics".
http://panasonic.ae/en/manuals/NA-F70B2-65B2.pdf
Posted on May 05, 2015
Panasonic NA-F80B2 doesn't filter Water to the machine
None ever have that I know of . the inlet hoses have a screen in to stop large chunks only
Jan 18, 2016 | Washing Machines
My washing machines NA-F65B2 Error code U12
This has already been answered elsewhere. Search "error code u12 for na f65b2". Find previous answer there
Jul 09, 2015 | Washing Machines
May 05, 2015 | Washing Machines
My panasonic waching machine model is NA F80B2 Error is U 11 U 14
Feb 06, 2015 | Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
PLUSTEK OPTIC PRP U12 will this scanner work with windows 7? 64 bit thanks
Improve the FixYa.com experience for everyone by voting!
The following link shows the compatibility chart your scanner: Plustek Compatibility Chart
The data set forth below is copied from that chart:
OpticPro ST Series Compatible with Windows 7
OpticPro ST28 OpticPro ST48 OpticPro ST64+ OpticPro S Series
All the best
Ben
Jun 18, 2011 | Plustek OpticPro U12 Flatbed Scanner
Hi friends, I have Panasonic washing machine model NA F90GS, I have got error at dispaly monitor code U12, could you please inform me what is that means for this code error, when I want to put the washing...
John C
Mar 13, 2011 | Washing Machines
Panasonic washing machine model no NA F70B2 U12 problem just installed today shows U 12 when the cycle reaches Rinse and does not move on.
Dec 30, 2010 | Washing Machines
Old plustek opticpro u12 scanner software, new Vista engine.
i have old plustek opticpro U12 Scanner software,
rigister s/n:52D11F002984
Dec 02, 2008 | Plustek OpticPro U12 Flatbed Scanner
43 people viewed this question
jasbo
jasbo
