Question about Hifonics Car Audio & Video
My hifonics zues zxi 500 x 2 does not come on when hooked up
I hooked the power then when I went to hookup the ground it sparked and started getting hot
jdrrwoods
  • 82 Answers
SOURCE: hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Posted on Feb 11, 2008
stitchnsound
  • 7 Answers
SOURCE: need help hooking up unit
whats the brand buddy
Posted on Nov 12, 2009
  • 9 Answers
SOURCE: when hooking amp directly to
your amp is bad. you should have a 12v, ground, and remote wire. if these are hooked up correctly, your amp is more likely broken, and needs to be repaired or replaced.
Posted on Jan 31, 2011
Jahn27
  • 1554 Answers
SOURCE: Kenmore Electric Dryer Model 110.69902890
The dryer operates both on 120VAC and 240VAC. The motor and the controls are hooked up on 120VAC whereas the heating circuit is on 240VAC.
The problem here is likely with the thermal cut-off and the high-limit thermostat located on the heater housing. Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Let us know if you need further advice. Please make sure you accept the solution should you find it helpful or informative. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Feb 01, 2011
  • 225 Answers
SOURCE: i just bought a punch
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
Posted on May 21, 2011
My hifonics Brutus 2000 watt has a dead short in it somewhere,as soon as you put power to it it blows the fuse,no lights nothing.any body got any ideas?i have it all tore apart now,but no burn spots
Call hifonics, they do flat rate repairs on their equipment for a reasonable rate. Most likely, you have a shorted mosfet transistor module in the power supply. these are not a smple repair, most local shops won't touch them. 25321271-zkea2bktkzr3q3lrmfdlr2m5-4-0.jpg
Dec 14, 2014 | Hifonics Car Audio & Video
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
I have a 81 honda cx 500 custom i rode it parked it went out next day and turn the key over and get nothing no headlight no power to anything hooked up jumper cables get no spark ran new ground wire get...
I had the same problem. I found the main wire connect (under the speedometer) around the sterring column had came loose. Very hard to re-connect but when I did everything worked perfect.
May 07, 2012 | 1982 Honda CX 500 A
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
May 07, 2010 | Hifonics BXi1608D Car Amp
I bought a hifonics bxi2006d new and doesnt turn on
you should not have any spark from your ground...you may want check and make sure your ground is properly installed. Try wiring the amp without the cap and see if that works.
Mar 28, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Where do i plug the rca cables at? there are two different places
Plug into the ones that say input, the other ones are to plug another amp into, so for just the single amp setup plug into the input.
Sep 15, 2009 | Hifonics Zeus ZXi ZXi 1006 Car Audio...
My amp is not working , i think i blew a channel please help
If you swap the rca cables going into amp if you still hear nothing from that side swap speaker and then check to see if it works. If not, you do indeed have a bad amp.
Jul 02, 2009 | Hifonics Zeus ZXi ZXi 1006 Car Audio...
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Power good no green light no subs
Make sure you got a good ground. do not ground on painted surfaces! If you got power from battery, check the remote wire running to cd player. Hook up remote blue wire with the one for cd player. If you still have a problem and the fuse is good, then the amp is fried
Jan 30, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
55 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
